Badger5AH Fabrications
    Dec 2012
    AUDI A8 2004 3.0 TDI Injector Failure advice needed
    Hi everyone I am new to the forum.
    I bought a 2004 Audi A8 from a private seller on the 14th of November car seemed perfect. It looked a very good buy with a full service history and a low mileage of 70k.
    Its my first Audi and I am really happy with it. I did do some research into possible issues to be had with this car but nothing I found seemed to warn of possible injector failure.
    Just over 1 week ago I noticed thick white smoke from the exhaust after start up. I kept the car idling and smoke continued steadily . I revved and loads of smoke piled out.
    I drove away concerned and the smoke disappeared after less than 3 minutes. The car appeared to be normal.
    I booked it into a local independent garage. They checked the oil and discovered it was much too full so they drained it. They also plugged It into the computer and it came up with only 1 small error on the control head.
    After a few days of feeling hopeful the smoke reappeared (See Video below) This time less thick but still white and smelt like oil/diesel.
    Cardiff Audi had a look at it on their diagnostics and found 3 injectors had faults and suggested replacing all 6.
    To replace all 6 injectors is going to cost £2987 - OUCH
    Has anyone had a similar issue on this forum or had any success with Audi contributing to the extortionate repair cost?
    Any advice or help would be much appreciated.
    Dec 2012
    Quote Originally Posted by a8starr View Post
    I had same issue. I contacted Audi dealer and they paid almost half of cost. Saved a bit but wish I had held out for more. It is a known fault with the 2004 valves.
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    822
    I'm not sure if the A8 has the same engine as the B7 A4 3.0tdi, but if it does there are no 'known' problems with the injectors.
    As a comparison the 2.0tdi 140 engine (B7 A4) has an injector recall out as they fail regularly. People have been able to get audi to cover the cost of the replacement if still under warranty but others have not been so lucky. It would be worth a try to ask Audi if they will do anything, but given that the car is 8 years old and there probably isn't a known fault with the injectors, I wouldn't hold your breath unfortunately.
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
  1. Audi A3 2004 2.0 Tdi Juddering
    By ik1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2012, 12:16
  2. 2004 AUDI A4 AVANT 2.5 TDI QUATTRO SPORT (180PS)
    By sc00byd00byd00 in forum For Sale/Wanted - Audi Cars
    Last Post: 14th May 2011, 20:34
  3. Audi A4 2004 2.5 tdi quattro sport only 58000 miles
    By Quattro180 in forum For Sale/Wanted - Audi Cars
    Last Post: 17th April 2011, 22:36
  4. 2.0 tdi quattro sline advice needed !
    By A4 TC in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th March 2011, 14:18
  5. Audi A3 TDI injector
    By Grako in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2010, 12:26
Tags for this Thread
