Insurance PrestigeGNJ
Thread: MPG
    a8tdi's Avatar
    Aug 2012
    30
    MPG
    Does anyone know roughly the difference in mpg when leaving the ac on constantly? My A8 is prone to some steamy windows, this only happens when its wet outside and i have read that leaving the air con on and at automatic should resolve this issue..
    Thanks,
    Sep 2012
    Glasgow
    Hi this is not going to be really helpful in answering your question but i have found out that if you run the air-con in econo mode eg air-con off your auxiliary heater doesn't come on ether. Which is a bummer when it gets really cold. As for the extra fuel it uses i haven't noticed it making all that much of a difference but then i'm only getting about 22mpg as it is. As for your steamy windows turning on the air-con clears them up nicely.
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,098
    Re: MPG
    It won't be that big an impact.
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Suj85's Avatar
    Nov 2012
    6
    I've wondered this too but I haven't bothered experimenting yet - far too cold to be messin round with that!
    Dec 2012
    15
    I find very little difference mpg air con on or off but try to keep your foot well carpets as dry as possible and occasionally lift out and dry in the wind or if you lucky enough to have a radiator in your garage or utility use that ....just try to keep the inside of your car as dry as you can...avoid eating takeaways in your car etc etc
    munchkincoupe's Avatar
    Aug 2010
    895
    Have you checked that your cabin/pollen filters have been changed at service time. I've had this causing internal moisture on previous cars!
  1. MPG on DIS fixed at last!
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2003, 13:10
  2. MPG
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2003, 09:18
  3. Miles and MPG record? Can you beat it???
    Last Post: 30th August 2003, 13:15
  4. Does anyone check their MPG?
    Last Post: 5th August 2003, 08:22
  5. I managed over 30 MPG!!!!
    Last Post: 28th May 2003, 09:58
