Monster MotorsportChris Nott
Thread: Water Drip
    a8tdi's Avatar
    Aug 2012
    30
    Water Drip
    This evening i parked my Audi and then noticed a small but constant drip from the engine tray under the front of the car. The water isn't anti freeze as its tasteless. I was thinking it was to do with the heater workings although i don't use my air con..
    Any ideas?
    Aug 2010
    1,540
    if its just water then i wouldnt worry too much. might be the heater box drain but as youve said youd not had the aircon on i doubt its that.
    are the plenum drains clear round the battery/servo area? a8s while different have similar drains to a4s/a6s. the dripping might be the drains partially blocked and slowly dripping water out insted of the water being able to run out.
  1. water dripping underneath the expension tank 2.4 v6 2002
    By scanny1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st May 2012, 10:57
  2. Water leak / dripping in passenger footwell when AC is on
    By Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2010, 21:10
  3. Replies: 14
    Last Post: 21st January 2010, 18:17
  4. Dripping water
    By steveh in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2005, 22:29
  5. Water staines on Seats
    By Mike_C in forum Detailing
    Last Post: 24th July 2003, 10:47
