EM TuningMonster Motorsport
    a8tdi's Avatar
    Aug 2012
    30
    Extended Warranty
    Just wondering if an extended warranty will cover dash rattles? I will ask the dealer tomorrow but in the mean time would be interested in anyones views/experiences with rattles and warranty resolves..
    Thanks,
    warren_S3's Avatar
    Oct 2007
    6,132
    I would think it would have to. My car is still within warranty but they've just had to replace the whole glovebox housing as it used to vibrate horribly at certain speeds. Took them ages to pin the rattles down which means I'm not flavour of the month in there right now, but as long as you have warranty they should have an obligation to attend to your vehicle in whatever capacity is required.
    a8tdi's Avatar
    Aug 2012
    30
    Extended Warranty
    Hope so, the car is great but the rattle does waste the whole experience..Good you got yours sorted..
    Thanks for your input..
    a8tdi's Avatar
    Aug 2012
    30
    Extended Warranty
    Just checked my Audi approved multi point approved check certificate.
    Number 137, check for interior trim rattles!
    Well either the engineer was stone deaf or this hasnt been done, although a tick is in the box.
    Also,
    Number 106, check and adjust tyre pressures..NSF was at 42 psi, OSF was 32 psi which is the correct pressure according to the book.
    Becoming a little suspicious about the whole Audi approved certificate..
  1. Audi UK cant sell an extended warranty at the moment !
    By imported_Pmcgeorge in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2005, 07:52
  2. Extended Warranty- Difference in quotes
    By trekbiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2004, 10:43
  3. Should I Buy Extended Warranty for my 2001 A4 2.8?
    By imported_Baldkingpin in forum Detailing
    Last Post: 10th July 2004, 22:06
  4. Extended Warranties
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2004, 19:09
  5. Extended warranty
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th October 2003, 12:09
