KowalskiDTUK
    Oct 2010
    Post Thanks / Like
    Brake pad warning light
    Hi,
    I've recently upgraded my front discs to a grooved and drilled one. I've also put on a set of OEM pads. The brake fluid was fully bled and refilled as well.
    However, the Brake pads warning lights came on. Can this mean faulty sensor? I don't really think its sensor though since it only came on after I changed the discs. Don't really know what's wrong unless Audi A8 doesn't like grooved/drilled discs?
    Can anyone please advice?
    c_dog's Avatar
    Apr 2008
    Sussex
    99
    Post Thanks / Like
    What type of A8 do you have?
    There is a common fault related to the wires leading to the pad wear sensor being streched over time and becoming faulty, documented with fix here audipages Front Brake Pad Warning Light Troubleshooting
    2001 A3 1.8T TQS
    1998 A8 2.8 Auto
