Badger5Volks Autos
    Oli.'s Avatar
    551
    heated seat retrofit
    Hello all
    Is it possible to retrofit heated seats into the latest A6, and do you know anyone that does this?
    www.bmvs-camperhire.co.uk VW California hire and sales
    Aug 2009
    200
    Like most things in life if your pockets are deep enough things can be done. Kufatec do the harness to add seat heating (Seat Heating - Harness - Audi-38961_M) however as you will see you will also need to change the climate control panel and add a number of other components. It may be that Audi fits the heating elements as standard to all cars just does not enable them unless you spec them. There was talk a while back of Audi adopting a policy of including options within the car but not enabling them. Not sure how you would check though. There is another option however, seems to be the same solution one as a kit (Audi Heated front Seat Kit - Carbon Fibre) and one installed (Aftermarket Heated Seats | Heated Car Seats Installation - AVS Manchester) for you.
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    Jun 2013
    158
    Not sure on an A6, but if it's like the A3, then you will need additional wiring and fuse work as well as the bits for the seat. On an A3 - the retro fit from Hazzy Dayz was about £2k.
  1. Heated seats retrofit
    By lionyo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th February 2011, 17:13
  2. Replies: 12
    Last Post: 11th March 2010, 18:22
  3. Audi A3 Heated Seats Retrofit Anybody???
    By EvolutionV in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th March 2010, 15:03
  4. Heated seat retrofit
    By M88JCP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2010, 20:20
  5. Heated Seats retrofit!
    By Ibzzzzz in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2008, 19:49
