Chris NottSky Insurance
    Jan 2014
    AMI Retro Fit Q's
    I am looking at installing an AMI cable into my 09 C6 MMI 3G High as my next mod, but can't find any sort of definitive guide for it. I don't really want to replace the CD changer (unless I have too) so am hoping its a reasonably simple and cheap mod to do. Regarding the lead, I've seen genuine ones on eBay for £250 (looks like a few leads tied together) but I've also seen smaller leads (just one wire) for only around £40.00. Will the cheaper lead work or do I need the other one?
    Your help as always is appreciated!
    2,152
    No the £40 leads will not work. You need one of these AUDI AMI iPhone iPod (Audi Music Interface) FOR MMI 3G - A4 S4 RS4 A5 S5 RS5 Q5 | eBay (That will fit all 3G MMI systems) then it will need to be coded for it to work. You will also be able to keep your CD-Changer it's not like the early 2G setup.
    Jan 2014
    Great, thanks B5NUT. Do you know of a guide anywhere to help me through it?
    2,152
    Sorry, don't have any guides. I'm currently retrofitted MMI 3G into my A6, and will be fitting AMI, but will only be connecting up the USB connections (If that's possible) as I don't have any apple products and never going to buy any so only need the USB interface. The cabling is very easy and you cannot get that wrong, but you will need either access to the hidden menu or VCDS to enable AMI.
  1. AMI retro fit?
    By geo_nr1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2009, 09:34
  2. AMI Retro Fit for Symphony III in MY09 A4
    By funkycat in forum In-Car Entertainment
    Last Post: 30th April 2009, 19:45
  3. Audi Navigation - Can I retro fit to an S3?
    By Parf7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2006, 00:36
  4. Retro fit Parking Sensors
    By 18ME in forum General Technical / How To
    Last Post: 17th June 2003, 15:49
