EM TuningBadger5
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By B5NUT
Thread: 2006 A6 2.0 tdi egr fault
    brian.n's Avatar
    Aug 2009
    29
    my car is a 2006 A6 2.0 tdi BRE engine code .
    went into limp mode last week and brought up a EML on dashboard.
    scanned it with VCDS and the following faults were logged.
    Address 01: Engine Labels: 03G-906-016-BLB.clb
    Control Module Part Number: 03G 906 016 HS HW: 028 101 255 7
    Component and/or Version: R4 2,0L EDC G000SG 9673
    Software Coding: 0000072
    Work Shop Code: WSC 00353 210 82099
    VCID: 7BF5E6813AAB6CC6CE5-802E
    3 Faults Found:
    001032 - EGR Sensor 2
    P0408 - 000 - Signal too High - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 255
    Mileage: 245387 km
    Time Indication: 0
    Date: 2014.04.29
    Time: 15:27:23
    Freeze Frame:
    RPM: 2268 /min
    Speed: 69.0 km/h
    Load: 38.4 %
    Lambda: -1.8 %
    Mass Air / Rev.: 705.0 mg/str
    Mass Air / Rev.: 945.0 mg/str
    Bin. Bits: 00000000
    001027 - EGR Valve (N18)
    P0403 - 000 - Malfunction
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 2
    Fault Frequency: 178
    Reset counter: 255
    Mileage: 245407 km
    Time Indication: 0
    Date: 2014.05.01
    Time: 11:23:11
    Freeze Frame:
    RPM: 1134 /min
    Speed: 17.0 km/h
    Duty Cycle: 84.4 %
    Voltage: 13.45 V
    Mass Air / Rev.: 550.0 mg/str
    Duty Cycle: 0.0 %
    Bin. Bits: 00000000
    001025 - EGR System
    P0401 - 000 - Insufficient Flow
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 245439 km
    Time Indication: 0
    Date: 2014.05.02
    Time: 11:24:46
    Freeze Frame:
    RPM: 1806 /min
    Speed: 15.0 km/h
    Load: 17.6 %
    Duty Cycle: 14.5 %
    Duty Cycle: 94.1 %
    Mass Air / Rev.: 390.0 mg/str
    Mass Air / Rev.: 650.0 mg/str
    Readiness: 1 2 0 0 0
    so i cleared all faults and went for a drive, drove much better but still with occasional flat spots . EML did not return.
    re scanned again, this time 2 faults.
    2 Faults Found:
    001025 - EGR System
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 245567 km
    Time Indication: 0
    Date: 2014.05.06
    Time: 21:45:24
    Freeze Frame:
    RPM: 1407 /min
    Speed: 0.0 km/h
    Load: 9.8 %
    Duty Cycle: 14.5 %
    Duty Cycle: 94.1 %
    Mass Air / Rev.: 595.0 mg/str
    P0403 - 000 - Malfunction - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 255
    Mileage: 245567 km
    Time Indication: 0
    Date: 2014.05.06
    Time: 21:45:39
    Freeze Frame:
    RPM: 1407 /min
    Speed: 0.0 km/h
    Duty Cycle: 84.4 %
    Voltage: 13.30 V
    Mass Air / Rev.: 585.0 mg/str
    Duty Cycle: 0.0 %
    Bin. Bits: 00000000
    Readiness: 0 0 1 1 1
    obviously a problom with the egr valve, im going to remove and clean it tomorrow but ive read that cleaning the type on my car does,nt work and that it should just be replaced? anyone know if thisis correct?
    i did initially think it was the anti shudder valve/ IMF that was the problem but no fault codes have come up for it. thoughts?
    2,184
    I know someone who has just had to replace his EGR due to the teeth on the plastic gears had start to strip, and caused the same fault codes as your first scan. Only option was to the replace the EGR unit.
    brian.n's Avatar
    Aug 2009
    29
    Quote Originally Posted by B5NUT View Post
    cheers for the swift reply,
    yes i have heard a similar story in that the soot build up puts stress on the drive gears and they eventually break or strip,
    also my local main dealer told me they just have to be replaced when faulty, cleaning wont cure the problom but they would say that i suppose.
    2,184
    Cleaning will prevent the teeth from stripping, but once stripped a new unit is required, as you cannot buy the gears. Best is to open up the side were the gears are and take a look. It takes very few tools to remove the EGR very much a DIY job.
    brian.n likes this.
    brian.n's Avatar
    Aug 2009
    29
    im going to remove it at the weekend and open up the drive housing to see whats going on, ill post my findings , thanks.
    Jun 2011
    138
    just get it coded/remapped out and if you want fit a blaking plate or egr delete kit
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    brian.n's Avatar
    Aug 2009
    29
    So i removed the asv and egr valves this evening. The asv looks fine, butterfly moving smoothly throughout its travel.
    Egr valve drive is damaged though.
    Stripped teeth clear to see there.
    So i guess ill have to buy a new one, darkside developments are the cheapest ive found online for a new one so far.
    As regards a egr delete kit i would do this were it not for the fact of the re map issue,
    Is it possible to do this with vcds as i have just bought the pro kit and could do it myself with a bit of guidance.
    2,184
    You would need a new ECU MAP to delete the EGR, and VCDS cannot write map files to the ECU.
  1. 2.0 TDI EGR VALVE
    By X2JPH in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd February 2010, 11:08
  2. 2.0 TDI EGR pipe
    By samuelt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2010, 15:47
  3. Issues with a3 tdi sportback..........fault codes......please help!
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th January 2010, 22:59
  4. 2.5 TDI - EGR Valve
    By hodgy0_2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2009, 13:11
  5. 2008 A4 2.0 TDi radiator to fit 2006 A6 2.0 TDi??
    By chodecz in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th June 2009, 19:36
