Volks AutosSky Insurance
    Apr 2014
    Huddersfield
    14
    DRIVERS SEAT BASE
    The rearmost part of the seat base on my new to me A6 is lumpy/uncomfortable in a way my similar mileage A2 isn't. The discomfort Suggests the previous owner was perhaps on the heavy side (always assuming I am allowed to call someone heavy in these politically correct days). Can the foam base insert be replaced or is it easier to look for a replacement seat on fleabay? Either way how easy is it to swap a seat given the airbag wiring and is it easy to wire in a supply for an electric seat? (Mine are cloth non-electric SE seats in blue)
    eh tu!
    2,180
    Easy swap, the seat is held in with 4 bolts and there is a connector going into the floor for the airbag plug. Electric seats will require new seat harness to be installed, not a straight forward job. You can buy new foam base but unless you have ever stripped a seat down and refitted it's a proper **** of a job and I would find a re-trimmer.
    Apr 2014
    Huddersfield
    14
    Thanks, seems similar to most audi seats, I was just hoping the electrics were pre-wired! Will vagcom be required to reset anything to do with airbag sensors after swapping? After being used to lumber adjustment on the A2 i miss it on the A6!
    eh tu!
    2,180
    I always disconnect the battery before removing any airbag device, and you won't get any airbag errors.
  1. Creaky drivers seat
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2006, 23:19
  2. holes in seat base?
    By mattp in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2006, 22:18
  3. Drivers seat wiring loom
    By Bongo163 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2006, 17:12
  4. Drivers seat problem...
    By JoeInIreland in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2005, 16:19
  5. My Drivers seat has the wobbles
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2004, 16:26
