Volks AutosAH Fabrications
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    3.0tdi Slow to start in the mornings
    Evening gents,
    The allroad is still struggling to start in the morning, it's cranks but doesn't fire for 10 seconds ish.
    I've had the battery changed and the glow plugs changed so far, I've been reading up on the inter webs and there seems to be mention of fuel pressure needing to be at 10 psi and there's a valve that commonly looses pressure over time, any one know anymore about this / want to suggest things to explore.
    No relevant fault codes start from either.
    2,159
    Only things I can think of are fueling or injectors. I take it you have no issues when the engine is hot?
    Dane's Avatar
    Cheltenham
    4,003
    No issues starting the engine at any other point, and no driving issues either, no stuttering or holding back.
    I think it's had injector work in the past IIRC but I'll check the receipts.
    It seems to be a fairly common issue with no clear cut solution, a new starter motor seems to have worked in some cases though
  1. Replies: 10
    Last Post: 11th November 2011, 09:32
  2. S3 slow to start in the morning
    By beanoir in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2011, 20:27
  3. first start of the morning
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd August 2011, 09:51
  4. A3 1.8T won't start in the mornings - Please Help!
    By A3Tomlin in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2010, 18:20
  5. Car won't start in the mornings!
    By JayA4Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2003, 08:45
