EM TuningJMB Retrofits
Results 1 to 12 of 12
    Mar 2014
    36
    19" to 20" Wheels question!
    I don't suppose anybody knows the details of the OE 19" split spoke wheels? Offset? Width?
    Also I've been told that these same wheels come in 20" on other models!
    I'm basically trying to find out if I can fit these 20" wheels to my s-line so if anybody knows the offset that these are are would also be helpful.
    Aly
    Aly's Avatar
    Jan 2012
    Stirling
    123
    Not sure of spec... But I'm sure they were only available on Q7's
    Audi A6 2.7 Tdi S-Line Quattro
    Aly
    Aly's Avatar
    Jan 2012
    Stirling
    123
    http://pages.ebay.com/link/?nav=item...BAY-GB&alt=web
    Is this the ones you mean? According to the spec they are Offset ET33
    Width 8.5j
    Aly
    Aly's Avatar
    Jan 2012
    Stirling
    123
    19" oem spec are as follows
    BBS Speedlines
    Offset ET43
    Rim width 8.5j
    Stud diameter 112
    Manufacturers pt number 8K0601025S
    Tyre size 255/35/19
    Mar 2014
    36
    These are the style I'm talking about http://www.ebay.co.uk/itm/Genuine-au...item1c3fa0179b
    I can see in this ad it states the wheel is from an S5 S-line et29, width?
    Im sure the rs4 shared these wheels too?!
    Aly
    Aly's Avatar
    Jan 2012
    Stirling
    123
    You'll struggle with such a low offset! Mines are original S5 wheels with an offset of 33 and it rubs on the rear... Even with a little negative camber! uploadfromtaptalk1398814457955.jpg
    Mar 2014
    36
    So et29 and et33 will cause rubbing if fitted to the a6!
    So what would the ideal offset be for 20" wheels fitted to the a6? And maximum width without rubbing?
    Aly
    Aly's Avatar
    Jan 2012
    Stirling
    123
    Someone on another forum has 8.5j ET35 with 245/35/20 on an Avant. But couldn't honestly say what would be best! Tyre choice has a big part to play as well... Some have bigger side walls as do my Bridgestones....
    Mar 2014
    36
    These are just some 19" varients ive found just to try and get an idea,
    AUD*4F0601025BA1H7, 19x8.5, et48. - Audi alloy wheels | Genuine new 19" Audi 7 Double Spoke | fits Audi A6 4F Saloon/Avant | Alloy Wheels Direct Ltd
    AUD 4F0601025BA8Z8, 19x8.5, et48. - Audi alloy wheels | Genuine new 19" Audi 7 Double Spoke | fits Audi A6 4F Saloon/Avant | Alloy Wheels Direct Ltd
    The above two links show the same wheel (part no is Different due to colour) and the dimensions are -
    19x8.5 et48. I'm assuming this is the std wheel that is fitted to the S-line!
    AUD*8J0601025N1H7, 19x9, et52. - Audi alloy wheels | Genuine new 19" Audi 7 Double Spoke | fits Audi A6 4F Saloon/Avant | Alloy Wheels Direct Ltd unsure what these are fitted to.
    Mar 2014
    36
    Aly, where exactly do your wheels rub.? Inner or outer arch?
    I'm just thinking if they rub on the outer arch, isnt it possible to machine the mating face down to get more clearance? Obviously without catching the caliper and inner arch!
    Aly
    Aly's Avatar
    Jan 2012
    Stirling
    123
    It rubs on the outer edge! I've enquired from Arch Enemy to roll the arches but apparently there are no arches to roll on the C6... I went to a local body shop and they said the same....
    Mar 2014
    36
    Quote Originally Posted by Aly View Post
    So with your 20" s5 wheels with et33, can you tell me if there is enough clearance between the wheel and inner arch And the brake caliper to have the wheels mating faces machined down just enough for the wheel to clear the outer arch?
  1. Alloy wheels question
    By johndow in forum Handling
    Last Post: 22nd December 2005, 15:34
  2. 19" wheel question ??
    By domcj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2005, 19:02
  3. Newbie Says Hi & Wheel Question
    By ditcher in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2005, 18:37
  4. New S3 wheels question
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2004, 15:11
  5. just another wheels question
    By darrenrally in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2003, 22:38
