EM TuningBadger5
Results 1 to 8 of 8
    Nov 2013
    17
    Inlet manifold fault
    Hello all.Had the engine warning light on and inlet manifold fault found.So got the rods done and all was well for about a week now engine warning light on again.Has anybody used fr r tunning to map out the fault? Or do I have to bite the bullet and get both manifolds with motors done at £400 a side? Thanks
    Apr 2014
    Aldridge
    11
    What car is this regarding
    Nov 2013
    17
    Sorry a6 2.7tdi quattro
    Jan 2012
    1,837
    And what are the fault codes??
    Nov 2013
    17
    The fault codes I don't know. The engine warning light came on about 2 months since,took the car to the garage and they found intermittant for glow plug in cylinder 4 and 2 intake manifold runner low limit not reached. So had a new set of glow plugs and 2 new manifold acctuator rods. Everything ok for a while now engine warning light on again,garage said if fault returns new intake manifold and motors required about £800 pound plus labour. Looking on the internet I found that fr r tuning do fix but can't find any info if this fix works.Any ideas would be appreciated thanks
    2,184
    As above you need to see what the fault codes are, before chucking money at the car. check out the users map someone local to you may be able to scan the car VCDS (formerly VAG-COM) forum
    Jun 2011
    138
    Quote Originally Posted by ainso View Post
    works and can recommend fr&r tuning have used them few times for all my audi's past and present
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    Nov 2013
    17
    Thank you everyone hope to get it sorted next week.
  1. Inlet manifold flap motor and Cooling fans eml fault code
    By dawudbhai in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th December 2012, 19:02
  2. polished inlet manifold??
    By aidank1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2007, 19:58
  3. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
  4. Dahlback Racing Inlet Manifold
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2004, 20:14
  5. Polished inlet manifold
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2003, 01:00
