Sky InsuranceVolks Autos
    Feb 2014
    13
    Engine Idling / tick over Problem
    Hi,
    Every now and again whilst sitting in traffic, the engine in my A6 2L TDI, 2010 s-line 170bhp, seems to jump between the low idle setting, approx.900rpm and then up to 1000 rpm and then settle down again back to 900rpm? Only happens occasionally?
    Is it just a case of asking garage to adjust tick over setting or something more serious?
    Thanks,
    Taff68
    Feb 2011
    littleborough lancs
    235
    mine has done the very same thing, but then it seems ok for weeks on end,
    I ran my fault Code reader through it and it came up with a map sensor problem ( map = manifold air pressure ...I think)
    could it be the same on yours?
    2,174
    Had a similar on one of my old A4's turned out to be the MAF, best get it scanned to see if a fault code appears. One thing to note there was no fault code with my faulty MAF.
    Feb 2011
    littleborough lancs
    235
    worth a scan anyway, as you never know, I was told mine could be the MAF. but then I was told no it cant ..coz its not got 1
    Jan 2012
    1,837
    MAF or DPF regen happening if it doesn't do it all the time.
    Get it scanned.
  1. Help me cure a random miss fire/rough tick over on idle please.
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2012, 23:02
  2. Engine Judders, clicking noise on tick over.
    By mark.colledge in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th December 2010, 15:57
  3. B6 S4 (V8)ENGINE NOISE ON TICK-OVER
    By davems4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2009, 19:18
  4. IDLE SPEED TROUBLE---hunts to find correct tick over speed
    By quattro25years in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th April 2009, 22:37
  5. Replies: 12
    Last Post: 19th May 2004, 11:06
