EM TuningBadger5
Results 1 to 21 of 21
    Nov 2013
    49
    Unhappy battery discharge
    Hi all
    Have been reading a few write up about heated mirrors and leaving the switch in the centre position and draining the battery
    I had a new battery fitted to my a6 c6 2.7 tdi avant about 3 months ago and all has been fine battery reading 100% on mmi as i was checking it every now and then
    Started car tonight and it sounded slugish so checked mmi and it said 10% went for a long run and charged to 100% checked charging
    14.1 with nothing on 13.8 loaded so i gues charging system o/k
    Then noticed i had left heated mirrors on which i never had done before could this be the issue
    turned it off so will see
    2,153
    When you say long drive how long is that, it takes hours for a battery to fully charge.
    Nov 2013
    49
    The car was standing for 2 days and i took it for a drive for an hour have read on other sites that it could be the mmi not shutting down
    will go to car now and check battery on mmi
    Nov 2013
    49
    Car has been standing for nearly five hours just checked battery showing 100%
    all points to heated mirrors ???
    2,153
    Takes longer than an hour to fully recharge the battery, I know MMI will say 100% but I won't trust that meter. Here is a link on lead acid batteries Charging Information For Lead Acid Batteries – Battery University , not sure what battery you fitted but here are the charging times for the bosch range it's on page 16 http://www.bosch.com.au/car_parts/en...roch_Final.pdf
    Do you have bluetooth on your car and is that working correctly?
    Nov 2013
    49
    Thers the original cradle and phone in the armrest which i do not use just use the bluetooth with my phone
    see what you are saying with the charge time
    will go to powerhouse and get a battery check done still under warranty (good job at the price the are )
    Still bugging me that the only thing out of place was the heated mirrors setting
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    out of interest how do you leave heated mirrors on, just by leaving the knob in the middle??? I always thought it was more intelligent than that...
    Nov 2013
    49
    Totally agree with you it should shut down when you take key out
    not saying it is due to the heated mirrors it,s the only thing that i can say i did different
    could it be the moduel ( relay )not shutting down it should not make any difference if it is on heated mirrors or not
    is there a way of testing might just leave it on and see if it does it again
    2,153
    Out of interest what MMI firmware are you running, the final version was 5570, could be worth upgrading if your out of date. However I would make sure that the battery has been fully charged up using a battery charger before upgrading, as the BT module can take a long time.
    Nov 2013
    49
    Hi thought about updating firmware but some say you need 3 discs some say one ,also a possibility of loosing some settings and corrupting ecu i am gettint tp tmc bluetooth 2012 map update
    is it worth the risk if there is any
    2,153
    There is a risk, but over the years I've updated dozens of systems and only had one failed BT module, the disks you can buy from Audi at the cost of around £5 the part number for the 3 disk set is 4L0 998 961
    Nov 2013
    49
    Cheers for that will give it some thought and see what benifits inget from an update going to check battery charge been standing all night and day fingers crossed
    Aug 2012
    77
    100% on MMI battery display isn't a good gauge as to battery charge/condition as it's totally ballpark.
    Mine read 100% and took 5 days on a CTEK charger for that to advise of full charge/peak condition.
    I ensure that any periods of non-use greater than 72hrs I have the battery on charge (in-situ) every couple of months and expect my battery (which is the original 2007 one) to last for another 3yrs minimum.
    Natch not everyone has a driveway or garage to allow charging whilst in the car.
    Nov 2013
    49
    Will have to agree that the mmi battery display is not a good indication of battery charge once again after 2 days of not using the car the mmi read 10% about 30 mile round trip read 100% did the usual charging checks all o/k
    So i put it on charge in situ and after 26 hours battery still not charged will go back to europarts let them test it looks like a duff battery
    thanks for all your comments will post results of battery test
    2,153
    How good is your battery charger, most of the small ones won't touch that size of battery. I got one of these and from flat to fully charges is just under a day. Clarke BC190 Battery Starter/Charger - Machine Mart
    Nov 2013
    49
    Its not a cheap item its a cbt (charger booster and tester) has charged numerous large batteries before on my vw lt 35 not a small battery and fully charges my old battery of the a6
    Would i need to recode the battery if it turns out to be faulty as i suspect which i did not do when i put the new battery on
    could this have caused any issues ??
    2,153
    Of the top of my head I cannot remember, but I'm sure I needed vag-com last time I changed the battery on the A6.
    Nov 2013
    49
    Not an issue i do have access to a launch diagnostic kit if needed i assume this kit will do the trick
    Aug 2012
    77
    Test of battery chargers seen here:
    Battery chargers tested | Product Reviews | Auto Express
    It took a full 5 days to totally recondition my 07 battery, so lucky I had another car to use, but as we know it's best to slow/intelligently charge our cars as opposed to getting the most robust charger with the highest rate
    VCDS measuring blocks will show the true battery status and anything over 75% is good, anything below and it will need to be reconditioned, a good intelligent charger will be able to tell you if you need to replace, namely if it's still going after 5 days and VCDS doesn't show an improvement then you'd be best to replace it.
    2,153
    Quote Originally Posted by carpetbagger View Post
    No Idea, I've only ever used VCDS & VAS
    Aug 2009
    198
    Leave the mirror switch on the "on" position and go out to the car before you go to bed (air temp will be cooler) and see if the mirror glass is warm. If it is then the module to switch the heating off when you take the key out must be at fault as the mirrors should not be active when the car is switched off and locked
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
  1. problem with electrics?battery or alternator??
    By rockstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2004, 20:36
  2. I took the battery out of ny TT and now my radio w
    By jondana in forum TT/TT-S/TT-RS Forum
    Last Post: 18th February 2004, 19:19
  3. Battery Loosing Charge.....
    By rickquattro in forum General Technical / How To
    Last Post: 14th January 2004, 16:38
  4. Battery Replacement / Auto Electric Windows
    By ozzy in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th December 2003, 17:22
  5. Battery Voltage
    By Naresh in forum In-Car Entertainment
    Last Post: 21st January 2003, 19:31
