Monster MotorsportBadger5
    May 2013
    20
    A6 gzw tcm software update
    HI!
    Can someone update software for my a6 gearbox- gzw . Now it's 0080 but new software is 0110
    I change oil and filter but need update software as still have problems going from 3-2 gear and 4-5
    2,180
    I think your only option would be to take it to the dealers, as you would would most likely need VAS to update the firmware.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    As I was one point thinking of doing DIY ECM/TCM flash I found 2 diags tools which could perhaps do update, one was VAG CAN PRO another is Abrites AVDI.
    There are also independent VAG specialists which have online VAS and are far cheaper than dealer, Link:- Diagnostic equipment of Audi VW Specialists Centre in London
    Do you have TSB/TPI with SVM code? I may even have flash file from when I collected stuff for myself.
    May 2013
    20
    Wher to find TSB/TPI svm code?
    It can be done with vag vas pc(Vag vas 5054)
    my gearbox
    A6 (C6) 3.0 l TDI 19.04 GZW 4F0910156H 0080 4F02A007 / NA4F37AA01
    gupsterg's Avatar
    Jun 2012
    279
    When your car is on a VAS machine with online connection user uses SVM code to gain SW update for car.
    4F02A007 / NA4F37AA01 is the Software Version Management (SVM) code.
    As you have code I think you have the TSB / TPI (Technical Service Bulletin / Technical Product Information)
    In that document is also the part number for the VAS CD , 4E0.906.961 Q / 8E0.906.961 P
    As to if dealer will sell you?
    You can do offline VAS updates via VAS5054 from what I've read but not sure as never used one.
    The indi garage I linked do have online VAS and can update car with SVM code, you may need to find one to ensure sucessful low cost solution to what you wanna do.
    But be aware that the SW for TCM is for use with updated Audi genuine oil / ZF fluid as per instructions in TPI / TSB, you may wanna read some info I placed here Link:- Tiptronic Oil Change DIY Update
  1. Software update for DSG from Superchips
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th June 2009, 05:16
  2. 26 D9 EGR ECU SOFTWARE UPDATE
    By jr001 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2009, 18:44
  3. S3 - Software Updates?
    By PaulAr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th August 2008, 09:45
  4. ecu software update..any ideals what for??
    By skooby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2007, 09:58
  5. RNS-E Software update
    By danc in forum In-Car Entertainment
    Last Post: 24th July 2007, 17:08
