HI!
Can someone update software for my a6 gearbox- gzw . Now it's 0080 but new software is 0110
I change oil and filter but need update software as still have problems going from 3-2 gear and 4-5
As I was one point thinking of doing DIY ECM/TCM flash I found 2 diags tools which could perhaps do update, one was VAG CAN PRO another is Abrites AVDI.
When your car is on a VAS machine with online connection user uses SVM code to gain SW update for car.
4F02A007 / NA4F37AA01 is the Software Version Management (SVM) code.
As you have code I think you have the TSB / TPI (Technical Service Bulletin / Technical Product Information)
In that document is also the part number for the VAS CD , 4E0.906.961 Q / 8E0.906.961 P
As to if dealer will sell you?
You can do offline VAS updates via VAS5054 from what I've read but not sure as never used one.
The indi garage I linked do have online VAS and can update car with SVM code, you may need to find one to ensure sucessful low cost solution to what you wanna do.
But be aware that the SW for TCM is for use with updated Audi genuine oil / ZF fluid as per instructions in TPI / TSB, you may wanna read some info I placed here Link:- Tiptronic Oil Change DIY Update
