AH FabricationsSky Insurance
Like Tree1Likes
  • 1 Post By gupsterg
Thread: Audi A6 V6 TDi and other VAG models swirl flap arm and butterfly repair kits
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    280
    Hi fellow members,
    The 3.0 TDi V6 is used in a lot of VAG models and the 2.7 TDi is derived from the 3.0 design so they both suffer from the "swirl manifold issue"
    Issues that can occur:-
    1) Swirl flap motor malfunction
    2) Swirl flap link arm wear
    3) Swirl butterflies bearing wear
    So first image showing engine bay location of elements:-
    Yellow text is cylinders numbering, green text is cylinder banks, red boxes swirl motors and code.
    Now remedy for faults:-
    1) Swirl motor can be purchased and replaced, VDO have an online catalogue for cross ref'ing.
    2) Swirl arm repair kit from VAG dealers can be bought cheaper than ebay offerings.
    Item 1 is swirl arm, 2 is the follower (orientation must be observed upon replacing), 3 is clip to secure follower.
    P/N is 059 198 212
    D
    escription is "repair set for intake manifold"
    Here is copy of my invoice if dealer say not exist:-
    Here is video from another owner replacing bank 2 swirl arm/follower
    Bank 1 is more difficult to do in situ as the clip to hold follower to manifold has to be guided on upside down.
    Some people who I have spoken to have either used a method of gluing clip to a tool then guiding it on or managed with sheer ingenuity!
    3) Swirl butterflies bearing wear can be repaired by these :-
    Here is video of dismantling of manifold after removal by another owner
    Where I sourced butterflies repair kit Link:- Audi | VAG | VW 3.0 TDI & 2.7 TDI swir flap intake manifold refurbisment | AirShox
    B5NUT likes this.
    Nov 2013
    49
    Hi great post not long owned my a6 c6 2.7tdi 2006 158k what symptoms should i be looking for if my swirl flaps are questionable as it seems to be running fine
    cheers Pete
    gupsterg's Avatar
    Jun 2012
    280
    You will get a MIL if there is any issue, just before you set key to crank engine the swirl flaps are actuated to see if function is correct. So if motor failed just at that instant you'd get MIL on cluster as soon as cranking finish. The tolerance for wear on the link arms is so tight that when the motor actuates a little percentage out it will throw a MIL on cluster. Excessive wear on bearings of butterflies can cause movement which can send link arms out and again MIL occur.
    Nov 2013
    49
    Cheers have no issue at press but good to know
    cheers Pete
    gupsterg's Avatar
    Jun 2012
    280
    No worries
    All the best
    Gup
    gupsterg's Avatar
    Jun 2012
    280
    Further info on butterflies repair kit
  1. Audi 2.0 TDi - V157 Motor for Manifold Intake Flap - Intermittent Fault P3103
    By tinochelli in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2014, 14:13
  2. A3 (8P) problem with xenon range and other VAG errors HELP!!
    By bifixz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2012, 14:42
  3. Bentley Golf Jetta Workshop Manual and other VAG Items
    By salsheikh in forum For Sale/Wanted - Other Make Cars & Parts
    Last Post: 9th January 2012, 21:24
  4. Will mirrors off other VAG models fit S3?
    By Veero in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2012, 17:35
  5. Seat Leon bits and other VAG bits
    By TimJK in forum For Sale/Wanted - Other Make Cars & Parts
    Last Post: 23rd June 2011, 19:44
