Monster MotorsportVolks Autos
    ZYX
    Nov 2012
    22
    Engine Temp Sensor Help
    Hey Guy's,
    As the title says, does anyone know where the engine temp sensor is located on an Audi A6, C6, 3.0 V6 Tdi, 2005....???
    And is it easy to access , does it require any strpping down etc...
    Thank you.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Hi,
    Remove the air mass meter from air filter housing and air intake hose to turbo and then you should see the temperature sensor ( G62 ) on a metal coolant pipe on rear end of engine.
    G62 is outlined in red below photo
    ZYX
    Nov 2012
    22
    Your a Gentleman, cheers Thanks !
  1. Temp sensor ! Help !
    By warrenlord in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2012, 09:49
  2. Engine temp sensor
    By lnewland in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2011, 19:47
  3. 2005 2.0 TDI engine temp sensor or glow plugs.
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st August 2010, 21:32
  4. ECU Engine temp sensor - difficult start when warm
    By James09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2009, 19:52
  5. Engine temp sensor part number?
    By MickM in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2009, 22:54
