Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By B5NUT
  • 1 Post By carpetbagger
Thread: audi a6 2006 mmi
    Nov 2013
    49
    audi a6 2006 mmi
    Hi just wondered if any one has had the same issue with their sat nav it was all working fine on the disc that came with the car
    version 2005 which is a genuine copy , wanted to update so i purchased a 2012 version of ebay which looked like a genuine copy
    (on closer inspection no sure if it is a genuine ) took original disc out inserted new disc seemed to update fine ,then an error message appeared (check disc )took disc out put it back in same put original disc in same error
    cant clear it any help please or is this a main dealer issue cheers
    2,180
    Do you know what version of the MMI software you are running, if you don't this my help or post a picture. Checking Audi MMI sofware version for Bluetooth compatibility - YouTube if your MMI firmware is very out of date then the later nav may not work till the MMI is updated but cannot say for sure as the cars I've had with MMI get updated with the latest version. Also I don't believe the older disk will work if the nav firmware has been updated with the later firmware.
    Did you get any error messages during the update, Also did it ask you to reboot after the update? Where about are you someone with VCDS may be able to scan the car and check for any error messages.
    If your MMI system is out of date then you may what to get the update disk to get it up to the final version 5570. One thing to note is there are always risks when updating the MMI firmware, Bluetooth modules and Bose AMPS have been know to fail during updates.
    carpetbagger likes this.
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    If the disc is questionable, you could probably do worse than reading it to an image file and burning it back to a Verbatim -R at no quicker than 4x (the slower the better).
    Or get a dealer to confirm whether it's dodgy or not, and if it is, report the couterfeit to eBay/PayPal, who will likely refund you.
    R
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    Nov 2013
    49
    Hi first off thankyou for your replies and the link for checking mmi version very useful
    Woke up this morning with a fresh head and tried my original disc which loaded
    then tried purchased disc which also loaded i put several locations in and navigated there o/k so putting it down to human error
    the following information was from the link provided
    sw No 4f0910730d
    sw index 1110
    sw date 14/10/04
    again thankyou for your comments
    FactionOne likes this.
    2,180
    The system may have just needed a full reboot. The software you are running is very old (9 years) and could do with being updated to the latest & final version 5570, you would get TMC, update phone compatibility & several other enhancements it's well worth the money.
    Nov 2013
    49
    hi would like to look in to that where would i get it from and would it need any main dealer work
    just a note after loadind 2012 disc i am sure i am receiving tmc,s
    not noticed any other new functions ,but was not really looking for any
    2,180
    The part number for the CD's is 4L0 998 961 and is around £5-10 from your local Audi Dealer.
    Nov 2013
    49
    Hi all update on mmi went to audi to purchase disc b5nut recommended after a bit of messing about and the salesman asking me where i got the part No from his reply was , yes i could purchase the disc and the price was around what b5nut said ( cheers for the info ) but i would be using it at my own risk as it could damage the mmi and the ecu as it it a new update on a old mmi ?
    has any one done this update any issues or should i just leave well alone (would like new version )
    2,180
    I've done the update around 30-40 times over the years and the only one dead module which was a BT module. However I've seen the BT module and a control head fail to update, but then updated on the second retry. The only thing I would say if you have had any trouble with the cd-changer (read errors or not reading cd's) then sort that first before doing the update.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Hi carpetbager,
    MMI FW 5570 disc 1 run it once, disc 2 run it twice, disc 3 run it once Link:- http://www.audi-forums.com/attachmen...s-mmi-high.pdf
    If you have no telephone module carpetbagger you can skip disc 2 completely and do only 1 & 3.
    I would recommend putting a battery recharger on the charge points in engine bay, some have done update whilst driving/running engine but if your car stalled or something unexpected caused power drain to MMI you may end up in sticky situation.
    All the best
    Gup
  1. Audi A4 2006 Crash Test
    By Dazmo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2010, 20:59
  2. Audi S3 2006 front bumper cover part #
    By RedlineRob in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2010, 03:48
  3. Audi A6 2006 - disable electronic handbrake (solenoid?)
    By chodecz in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th June 2009, 19:34
  4. OIL change in audi A3 2006 2.0 TDI
    By fesss_84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2007, 17:19
  5. Reliability Of Audi A6 2006 3.2L
    By clvnng in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th April 2007, 03:45
