Sky InsuranceChris Nott
    Andi's Avatar
    Jun 2012
    London, UK
    17
    Access the Boost Pressure Sensor on 3.0TDI
    Is there any technique to accessing the above without either tiny hands or dismantling the front of the car?
    Just need to unplug and replug the connector...
    There's bags of room on a Q7, sadly it's not this clear on an A6...
    /// Andi :: 2010 A6 Avant V6 3.0 TDI Le Mans in Phantom Black
    .: VCDS Mods: VIM, Needle Sweep, Passenger Mirror Dip, Oil Temp with Lap timer, APS+ enabled
    Andi's Avatar
    Jun 2012
    London, UK
    17
    So, no response so I'll fill in the detail in case anyone else is interested.
    It's a PITA, but you can just about get to it by moving the Power Steering reservoir out of the way...
    • Remove engine cover to get clearer access to the bottom right area
    • Undo the single star-screw in the clamp holding the Power Steering resevoir
    • Push the resevoir through the clamp and down and to the right, as far away from the intercooler pipework at possible
    • In the space you've just created, put your hand through and underneath the metal intercooler pipework
    • You should be able to feel a connector underneath which you can undo JUST! You may need to pull a little bit of loom to get some slack. Mine was so tight the connector had no give to actually move off
    • Remove hand and look at the bruise and scratches you've just acquired!
    Long and short of it, tdi-tuning.co.uk dual channel diesel tuning box now installed, and a great addition!
    Pah, who needs skin on the back of your hand, anyway... !
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    74
    Was just typing out a reply lol - you can get at it without removing anything
    If you feed the rubber water pipe under the hard plastic water pipe (left in direction) you can get you arm down the small gap between the power steering pot and the intake pipe
    Reach down until you can bend your elbow - feel around for the plastic clip on the boost sensor - push it on first then press the release part of the clip (makes it easier to release)
    Andi's Avatar
    Jun 2012
    London, UK
    17
    Part of the issue was I wasn't 100% where the sensor was, so I had to explore!
    But I see your reasoning though it would still be pretty tight.
    It was handy having the p/s pot moveable for routing of the TDI box wiring underneath.
    Not sure where to secure it, though... Currently wedged in the inner wing with some number plate tape - but that's far from ideal.
    I may look at re-routing it to the scuttle area in the future, but I'd need to make holes, etc for that..
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    74
    I cable tied mine to the bracket of the abs pump on the inner wing
    Once you know where the sensor is you don't have to remove the p/s pot.
    I was going to mount my DTUK tuning box in the scuttle panel too, but no real place to get throu the bulkhead without seeing the cable - completely hidden cable tied to the abs pump bracket
  1. Does anyone know the 210 S3's standard boost pressure...
    By Benjiman46 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2012, 12:06
  2. A3 sport 130 N75 valve & Thrust sensor(boost pressure sensor) brand new genuine
    By BuckleyTDI in forum For Sale/Wanted - Audi Parts
    Last Post: 5th March 2012, 13:11
  3. what harness goes in too the A/C high pressure sensor?
    By auditj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2011, 01:57
  4. Safe Running Boost Pressure For 2.0TDI Hybrid Turbo
    By Lance-22 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2011, 22:00
  5. Anyone know the STD boost pressure on a a3 tdi?
    By MAD_Adamski in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2010, 15:32
