Good Day All
Would someone help me to find mistake source for 00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5) please. And one more thing for what is responsible Address 07: Control Head - Cannot be reached. Thanks in advance
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Tuesday,05,November,2013,00:56:52:26868
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62
72
VIN: WAUZZZ4F65N113622 Mileage: 220730km/137155miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 BF HW: 028 101 185 0
Component: R4 2,0L EDC G000SG 9553
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 68D5450A5B1B2F5E3C3-803D
2 Faults Found:
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics SUSPECT THET STEERING HAVE BEEN CHANGED BECOUSE THERE IS NO BUTTONS
Freeze Frame:
RPM: 882 /min
Torque: 30.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 1.0
17054 - Glow Plug Module 1; Glow Plug Circuit DONE
P0670 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 966 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Bin. Bits: 11001000
Temperature: 11.7°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02327 785 00200
VCID: 2C5DF91A8F63C37E18B-8079
No fault code found.
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300146732
Coding: 0000017
Shop #: WSC 02323 785 00200
VCID: E3CFD226223DCC06691-80B6
Subsystem 1 - Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043
Component: KLIMABETAETIGUNGH04 0150
Revision: 00000025 Serial number: 00000000125946
Coding: 0001044
VCID: DBBFEAC61A4DF4C6211-808E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Shop #: WSC 02335 785 00200
VCID: 2855050A9B9BEF5EFC3-807D
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
5 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 249
Mileage: 209444 km
Time Indication: 0
Date: 2012.11.07
Time: 09:42:00
00978 - Lamp for Low Beam; Left (M29) WORKS
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 220732 km
Time Indication: 0
Date: 2013.11.05
Time: 01:46:00
00979 - Lamp for Low Beam; Right (M31) WORKS
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 33
Mileage: 220712 km
Time Indication: 0
Date: 2013.11.04
Time: 06:58:00
01494 - Bulb for Parking Lamps; Left (M1) LED
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 220732 km
Time Indication: 0
Date: 2013.11.05
Time: 01:46:00
01498 - Bulb for Parking Lamps; Right (M3) LED
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 220732 km
Time Indication: 0
Date: 2013.11.05
Time: 01:46:00
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 C HW: 4F0 959 655 B
Component: 3E AIRBAG AUDI8RH29 0230
Revision: 06H29000 Serial number: 0037LD06AB5X
Coding: 0013125
VCID: 275706369685E026F59-8072
Subsystem 1 - Serial number: 6332CSME09790C2DD
Subsystem 2 - Serial number: 6342CSME0A027211S
Subsystem 3 - Serial number: 6351HSME07006376$
Subsystem 4 - Serial number: 6361HSME0701211E.
Subsystem 5 - Serial number: 6371VSME064C5A1F-
Subsystem 6 - Serial number: 6381VSME07054A4DR
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025050780025
Coding: 0100001
VCID: E6C9CB32D10FB92E8EF-80B3
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 N
Component: KOMBIINSTR. M73 H10 0630
Revision: 00700000 Serial number: 4R570VH35
Coding: 0262803
Shop #: WSC 50741 067 57207
VCID: 1E3923D2C9DF21EE86F-804B
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080532000B1
Coding: 6CEE53C41B0104
Shop #: WSC 02325 785 00200
1 Fault Found:
00384 - Optical Databus AFTER MARKET RADIO PIONEER PRS-80
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 141
Mileage: 219001 km
Time Indication: 0
Date: 2013.09.16
Time: 16:18:27
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
Component: TSG FA H11 0040
Coding: 0000538
VCID: 2A51FF028597DD4EEA7-807F
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 D HW: 4F0 907 289 D
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01003309430000
Coding: 0000133
VCID: 2B5FFA068A6DC446111-807E
Address 47: Sound System AFTER MARKET RADIO PIONEER PRS-80
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000048164
Coding: 0001004
VCID: DEB9E3D2095FE1EE46F-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H11 0040
Coding: 0000538
VCID: 2953000E8091D656E3D-807C
1 Fault Found:
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 219001 km
Time Indication: 0
Date: 2013.09.16
Time: 16:17:36
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000111
VCID: DDBBE4DE0459FAF65F5-8088
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000007673
Shop #: WSC 00000 384 00290
VCID: 234F1226E2BD0C06A91-8076
Subsystem 1 - Part No: 310 314 E04 G
Component: von TU3 310314E04G
Coding: 333130333134453034472054553333313033313445303447
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H11 0030
Coding: 0000002
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H11 0030
Coding: 0000002
When checking mirrors glass with tester its seems like they are fine.
Thanks in advance for your help and time
72
Coding: 0000072
2 Faults Found:
Freeze Frame:
RPM: 882 /min
Torque: 30.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 1.0
Freeze Frame:
RPM: 966 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Bin. Bits: 11001000
Temperature: 11.7°C
Bin. Bits: 10110000
Coding: 0020855
Coding: 0000017
Cannot be reached
Coding: 0001044
Coding: 0000101
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
5 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 249
Mileage: 209444 km
Time Indication: 0
Date: 2012.11.07
Time: 09:42:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 220732 km
Time Indication: 0
Date: 2013.11.05
Time: 01:46:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 33
Mileage: 220712 km
Time Indication: 0
Date: 2013.11.04
Time: 06:58:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 220732 km
Time Indication: 0
Date: 2013.11.05
Time: 01:46:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 220732 km
Time Indication: 0
Date: 2013.11.05
Time: 01:46:00
Cannot be reached
Coding: 0013125
Coding: 0100001
Coding: 0262803
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 141
Mileage: 219001 km
Time Indication: 0
Date: 2013.09.16
Time: 16:18:27
Coding: 0000538
Coding: 0000133
Cannot be reached
Coding: 0001004
Coding: 0000538
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 219001 km
Time Indication: 0
Date: 2013.09.16
Time: 16:17:36
Revision: C63C0030
Coding: 0000111
Address 56: Radio
Cannot be reached
Coding: 0000002
Coding: 0000002
