Volks AutosEM Tuning
Thread: a6 rear window
    Nov 2013
    49
    a6 rear window
    Hi have been reading the forum for a while, now time for my first post have owned my audi a6 c6 2.7 tdi avant 2006 for nearly 4 months apart from 2 recalls and some warranty work done by garage car has been sound.
    However parked the car up after going out this morning and rear n/s window was down so tried to close it ,it would go up so far stop then come back down tried from drivers cluster and rear door switch
    to close I had to inch it up is there a sole sensor for each window?
    any help please
    Jan 2012
    1,837
    Yes there is a sensor in each window for pinch protection.
    I suggest getting a fault code scan done and send someone from the VCDS User Map to help.
    VCDS (formerly VAG-COM) forum
    Nov 2013
    49
    Hi cheers will get scan done and post results
    Aug 2009
    200
    I had the identical problem (same window!!) on my wife's Mk6 Golf at the weekend. Managed to "cure" it by lowering the window all the way and holding the switch in that position for a few seconds and then repeating it at the closed point. Seems to be OK now. Worth a try
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    Nov 2013
    49
    Cheers well worth a go did exactly what you said opened the window held the switch down then went to close it it stopped halfway up tried it again and it closed so held switch down seems to be working fine (is this a reset procedure or just coincidence ? ) either way cheers but will take door card off and spray window runners
    Aug 2009
    200
    Quote Originally Posted by carpetbagger View Post
    Sorry meant to have replied sooner but been very busy. I do believe that this is a reset procedure for the upper and lower limit points
    1970 Lotus Elan +2S
  1. Rear Window Heater
    By steveh in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2005, 13:53
  2. Removing the rear window wiper...
    By imported_trident21 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2005, 14:48
  3. Rear windows on A3
    By imported_mwilliamson88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2004, 14:03
  4. HELP!! Heated rear window and wing mirror problem
    By tboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th November 2004, 14:14
  5. 80 Cabrio Rear Window
    By Melwoods in forum Classic Audi Forum
    Last Post: 25th August 2004, 22:26
