AH FabricationsBadger5
    Sep 2013
    6
    Removal of wire or vacume pipe to intake manifold actuator???
    Hi, really hoping someone can give me a pointer here. I have my EGR Valve off, and the manifold it attaches too, but cannot get the manifold off the car as there is a thin black pipe to an actuator that controls flaps in the manifold.
    How do I disconnect this? I have pulled with moderate force but I dont want to break anything. I think its a vaccume pipe, but it could be a wire I suppose.
    Tips appreciated. I have a photo, if only I can post....
    Dave
    Sep 2013
    6
    FYI, its a 2.0 TDI BRE. Picture of the manifold half off here http://sdrv.ms/19hqmRu
    Thanks in advance.
    Sep 2013
    6
    Well, I went back and had another pull and it came straight off..... Fitted new EGR Valve, (£157 from gsf parts), due to worn tooth in actuator gearing, and cleaned out manifold, it now accellerates MUCH better even than when I got it at 60k, now 110k, and I think fuel economy may have improved, but time will tell on that.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    I keep a hairdryer in the garage ... I use it to give hoses a little heat to make them come off easier :D ...
  1. air intake manifold, actuator and flap
    By Reddevil74 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th July 2013, 13:01
  2. Urgent Help Needed! Where do these wires and this pipe go? AUM 1.8t
    By Lingo89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2012, 15:07
  3. 2.0 FSI Inlet/Intake Manifold Removal
    By jlawie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th June 2012, 11:25
  4. Removing bose wiring loom
    By nazS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2012, 20:20
  5. Rear Footwell Lights/Door Trim/Carpet Removal - Routing Wires
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2012, 16:32
