Sky InsuranceVolks Autos
    Jul 2010
    Birmingham
    66
    auto lights and wipers not working
    The auto wipers has never worked on the car the windscreen was replaced due to a crack and a new gel was put on when trying to put wipers on using the stork on auto setting it stays on intermittent also when selecting auto lights they are on constantly if its dark or not. I have had a look in vcds and it seams that the sensor is enabled i have flowed the these instrctions would this work even tho there for a passat http://www.myturbodiesel.com/1000q/b7/vw-passat-auto-wiper-activation.htm
    2002 Audi A3 1.9 TDi 130 SE
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    280
    Hi ...
    Access module 09, select coding, then pick option show in video below, point of accessing rain light sensor section is at 0:58 ...
    The drop down menu will make adjustments to rain/light sensor, ref this link as well Link:- Audi A6 (4F) Rain/Light Sensor - Ross-Tech Wiki
  1. Interior and rear right brake light and indicator not working
    By plymouthaudi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2013, 15:56
  2. Auto lights and Wipers - Central electrics question
    By jin2 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th November 2012, 12:42
  3. Auto lights and wipers
    By Legend7 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2012, 14:32
  4. Does S-Line 03-05 A3 have Auto Lights and Wipers?
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd June 2009, 15:44
  5. Interior lights and sunroof not working?
    By wayneharrow in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2008, 17:15
