Volks AutosSky Insurance
    Oct 2012
    390
    Side light wierdness
    Hi all,
    friend of mine has an 03 plate 1.9tdi saloon, i noticed the evening that all his drivers side sidelights were out front and back, so we checked bulbs all ok checked fuse all ok, when you use the indicator stalk as a parking light it all works fine, wtf guys?
    As a temporary measure i have popped a couple of jumper wires on the back of the fuse box from the left hand side to the right all is good again, but i really don't think it's a permanent fix. There is no power to the fuse for that side either, do we think the switch is toast?
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    262
    You describes some odd behaviour, as all work ok when using indicator stalk to set parking/side light but not work via switch and you have no power on a fuse ...
    Perhaps wiring diagrams will aid you?
    PM external email :D ...
    Also I think this thread need to be in A6 C5 section as yours is an 03 1.9 TDi ...
  1. Side lights come on when brake pedal is pressed
    By Kevint in forum Other Brands & Models
    Last Post: 30th October 2005, 14:22
  2. Side Lights, how the hell do you change them????
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th September 2005, 11:58
  3. how to remove side light bulbs?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2004, 13:04
  4. Side Lights
    By bampy in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2004, 22:15
  5. New A3 Side Light Bulb Change
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2004, 21:01
