JMB RetrofitsAH Fabrications
    May 2013
    20
    a6 3.0 tdi injector sealing WASHERS
    Need to get sealing WASHERS for 3.0 tdi injectors but can't find part nr.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Hi,
    This diagram is for the later EU5 V6 fitted 2009 - 2011 Link:- Fuel rail injection unit pressure pipes 2,7/3,0ltr. 3,0l. Fits: 2010 Audi A6 | Jim Ellis Audi Parts
    The earlier 2004 - 2009 is near identical diagram ... item 30 on diagram P/N 059 130 519 , approx. £3 each @ dealer ...
    You can also see it here on the photo of an injector I fitted to mine :D ...
    May 2013
    20
    how to remove injector
    gupsterg's Avatar
    Jun 2012
    279
    Hi,
    Here is my how to guide :D ... Link:- Audi A6 4F C6 V6 2.7 3.0 TDi injector removal / installation
    The tools I used were:-
    i) Laser 4640 injector puller Link:- Laser Tools | 4640 | Impact Diesel Injector Remover VAG
    ii) Laser 4984 difficult access sockets for the fuel pipes Link:- Laser Tools | 4984 | Difficult Access Socket Set 3/8"D
    I bought both from ebay Laser 4640 = £40 , Laser 4984 = £25 , I know of members on another forum just removed injectors by hand/homemade tools ...
    May 2013
    20
    I made tool for hitting out injector.
    Now i need injector as when was removing small pipe on top of injector i broke this small nipell on side of injector.
    Maybe some one selling some injector for 3.0 tdi
    and i need done all till tuesday as i'm going on holidays.
  1. 2.5v6 tdi injector seals!!!
    By Yappy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd April 2012, 23:56
  2. 2.5 tdi Rocker/Injector Seals?
    By Rossy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th July 2011, 06:50
  3. A6 C5 Allroad 2.5 TDI Injector Seals
    Last Post: 9th July 2011, 20:02
  4. oil leak injector seals audi a4 2.5 tdi v6
    By eliasuk98 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2011, 22:29
  5. V6 TDi injector seals
    By dan1 in forum Diesel forum
    Last Post: 28th January 2010, 21:10
