Monster MotorsportVolks Autos
Results 1 to 11 of 11
Like Tree4Likes
  • 2 Post By gupsterg
  • 1 Post By Chadders
  • 1 Post By Forbez
Thread: Removing headlights
    Mar 2007
    21
    Removing headlights
    Hey guys, I'm thinking of getting some tints for my headlights, so thinking of making it easy to fit them, that removing and fitting the tint away from the car would be best.
    I've done abit of searching, and couldn't find anything other than a video of two guys struggling to remove a bumper.
    Hopefully this isn't a bumper off job.
    Cheers Tom
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    65
    Yes, it's a bumper off job
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    255
    Hi fellow members ... this is how I removed my front bumper...
    First removed undertray i) first the smaller one, held on my 2x screws (yellow boxes) ii) then the bigger section via 9x screws on lower side and 4x plastic ones in the wheel arches (red, green, blue)...
    Then I next removed 1-2 screws in wheel arch to be able to lift the wheel arch liner to access these 3x screws (repeated on other side)...
    Then I undid nut (red box, 4nm) with standard socket & extension bar, universal joint aided to get correct angle (repeated on other side)... note locating element of bumper edge on wing in blue box...
    Next I removed the plastic lock carrier cover, lift at front (note green line below image), then slide/detach towards front of car... then remove 3x bolts (red boxes, 8nm)...
    The bumper has a clipping system where green line is on below image, I unclipped it by pulling it outwards at orange line... as I was aligning headlights within body cavity and restoring equal gaps around lights on grill/bumper/wing I found lubricating the clip system on bumper aided repeated removal and refit to get gaps correct... I also placed blu-tack at blue line to stop bolt from scratching wing on removal...
    I had placed a sheet on the ground and some empty 5L bottles as cushions under front of bumper... at this point I had a helping hand to remove bumper by sliding it forwards off body... I detached cables for foglights and washer system then put it aside...
    There is a removal clip on washer system located at blue arrow, I angled hose connector upwards and put an ear plug in it to stop screenwash flowing out ...
    The alignment gaps...
    The blue lined ones are taken care of by the 3x bolt/spacer system on headlights... I found that by adjusting headlight to top/side of wing by eye then leaving bolt in blue box slightly loose, refitting bumper and adjusting bolt/spacer in red box and yellow box was quicker/easier, see photo below ... I used plastic topup cards as spacers for gap measuring, they were roughly 1mm thick so taped some together to create 2mm & 3mm spacers and placed appropriately then tighten bolts/spacers... I accessed yellow bolt/spacer through wheel arch whilst bumper was fitted, see second photo below ...
    The green lined gaps main adjustment is by the green boxed element, the red lined gaps main adjustment is by the red boxed element... ref image below with text of alignment gaps...
    I found if I moved the red element two high the bumper will not fit over the green element they need to be adjusted together but the finer adjustment of each gap is done via each separate element ...
    Here's a close up of the red element ...
    Unscrewing it upwards closes the gap at red lines, screwing it down does opposite ...
    Same principle with the green box element ... here is a close up if that ...
    Unscrew move up to close gap, move down to create gap ...
    Refit is reverse of removal...
    The red lined gap is suggested 5.5 mm ± 0.5 mm
    The green lined gap is suggested 1.2mm (Note: the bottom edge of the headlight must be parallel with the top edge of the bumper)
    The yellow lined gap is suggested 2mm (Note: the headlight curve is flush with wing, the gap is the outer edge of headlight meeting outer edge of wing)
    The turquoise lined gap is suggested 2.3mm (Note: the headlight sits up & under top section of wing, the gap is between there)
    The purple lined gap is suggested 2.3mm
    These gaps will aid reduction of vibrations from body/engine going to headlight making bulbs/headlight move/resonate...
    There is a repair kit for the headlight mounting eyes... 4F0 998 121 for left ... 4F0 998 122 for right ...
    My issue was not any fault with lights, etc... I just wanted great gaps
    fishyfish and Chadders like this.
    Mar 2007
    21
    Thank you very much for your response, looks quite detailed. I think I'll spray the grill the same time as I remove it to fit the headlight tints.
    Thanks again.
    gupsterg's Avatar
    Jun 2012
    255
    No worries :D ... be great to see of your mods ...
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    612
    Where did you get the measurements from. Is there one for a B6?
    Im looking for something like this!
    gupsterg's Avatar
    Jun 2012
    255
    I'll dig some up & PM you ...
    Oct 2012
    Yatton
    156
    I've no interest in removing my bumper but well done Gups top bloke
    gupsterg likes this.
    Mar 2007
    21
    I must say this is one of, if not the best reply I've ever had to a question on a forum. Again thank you, and I'll will post pics.
    Still undecided on whether to tint headlights or not. I think it will look awesome, but will I be able to fit them properly, and will they be too dark/ cause problems with my headlights.
    Think I'm going for some lamin-x tint.
    gupsterg's Avatar
    Jun 2012
    255
    Quote Originally Posted by SL11 CKK View Post
    Done PDF :D ... PM an external email mate ...
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    612
    Quote Originally Posted by gupsterg View Post
    PM'ED!!!!!!!
  1. Bulb cracked - now to remove headlight lense
    By davej_anderson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2009, 20:46
  2. Front Indicator Bulb Replacement - Remove Headlight?
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th June 2009, 08:07
  3. How do I remove headlight level motors?
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th August 2006, 15:55
  4. Removing headlight units
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2005, 17:09
  5. Replacing/Removing Headlights
    By imported_unkle in forum Tuning
    Last Post: 12th November 2004, 16:15
