Free BT Voice control ...
gupsterg
Lurking over a keyboard!
Hi peeps
I was going to add voice control at some point to my car...
As a test I enabled voice control in the bluetooth module...
Ref link:- Audi A6 (4F) Telephone Preparation - Ross-Tech Wiki
[77] - Telephone
00x0x?0: Voice Control Language
  • 2 = English (United Kingdom)
So before....
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007540751
Coding: 0010900
Shop #: WSC 00000 000 00000
VCID: 2C5D2F5B8F1CFD78ADD
The after....
Coding: 0010920
I must have tried 4-5 times to get it to dial a number... in the end I just used the manual method
... I did get it to work a bit better after some practise...
At least now though when I press button on steering wheel it does not say "But not used"...
Not bad for a freebie though
Yep it only allows telephone module related controls ... I did it several months ago :D ...
I only post experience today as I saw a query relating to the A6 in this thread on the forum Link:- http://www.audi-sport.net/vb/audi-s...7443-voice-control-worthwhile-option-not.html and thought I'd share :D ...
If you have factory fit telephone prep then to get full voice control you only need to add a SDS module to the K Box ...
Component protection removal is required and some coding in Link:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Gateway J533
SDS module language can also be changed via MMI update discs ... with SDS module in place you get:-
It perhaps may have other functions with say AMI or TV but don't know :blush: above info from an A8 SSP ...
The mod in post 1 works on the 2nd & 3rd module 77's shown on Link:- Rosstech wiki for 4F
This is an awesome freebie for the safety factor alone! Can't tell you how much I dislike trying to locate and dial the missus while driving (usually to give an ETA on picking her up or whatever).
Unfortunately, I may have my ears boxed to a pulp if I splash out on a VCDS cable right now, as four new tyres tomorrow means I am already in trouble with the money police :)
7
942
718
487
