Chris NottSky Insurance
    Apr 2013
    Aberdeenshire
    586
    Audi a6 brakes dragging
    Hi my friend has an 05 plate 2.7 tdi he has been having issues with both his rear brakes dragging and causing his wheels to get very hot he has had the car looked at with no faults found wheels spinning freely assuming this rules out basic brake issues could the electronic park brake cause these issues if not releasing correctly the car was scanned with no related codes however I am yet to scan it with my vcds any help would be appreciated
    Mar 2007
    38
    I had a very similar problem on my 3.0.
    It came down to a seized caliper and since the electric parking brake was involved the cost for the replacement was £600 !!
    Mine was accompanied by a throbbing noise as well as the wheel getting hot, so much so that when I took a technician out to hear the noise, the brakes failed with vapour lock !! Fortunately, not totally.
    Partly to blame, I was told, was not using the brakes often enough !!
    Hope you get it sorted more cheaply.
    marsmail
  1. Audi S3 brakes???
    By jordan m in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2010, 20:43
  2. Audi s4 brake pads
    By Nez in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2009, 23:29
  3. Audi RS4 Brake disc
    By wazazz in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 13th September 2009, 20:35
  4. Audi A4 brakes
    By coyote in forum Parts Requests
    Last Post: 24th July 2008, 09:39
  5. Audi s3 brake fluid capacity
    By simch in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2007, 22:03
