Results 1 to 7 of 7
    Josh84's Avatar
    Feb 2011
    Leeds
    74
    Fitting rear parking sensors
    Hi all, when I bought my a6 it had parking sensors in the rear bumper. They dont do anything and im not sure if they are connected to anything. Just want to know what is needed to get them working, and if its a big/expensive job if in the worst case scenario they arent connected to anything.
    Thanks in advance.
    2005 Audi A6 2.0TDI S Line- Black
    2004 Audi A3 2.0TDI Sport- Akoya Silver
    2006 Corsa 1.4 SXI+ -Black
    1996 Ford Fiesta (think it had an engine)
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Are they factory fit, do they sit flush or are they sitting on top of the bumper slightly raised.
    They have been disabled by removing the fuse to the controller. One sensor may have been faulty and causing a nuisance.
    See if you can post a pic of the sensor mounted on the bumper.
    Josh84's Avatar
    Feb 2011
    Leeds
    74
    I think the previous owner changed the bumper for 1 with the sensors in so they will be factory fit, but he never got round to doing anything with them. They do fit flush, you hardly notice them.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    OK, that makes sense, so you can buy a loom for the sensors and the 4 channel module and your in business. There is a grommet on the right hand side when the bumper is off to feed the cables through.
    Josh84's Avatar
    Feb 2011
    Leeds
    74
    How much am I looking at for these? Am I best going to audi for them?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Kufatec.co.uk can sell you the wiring.
    Possible also a controller, it's cheaper than the whole kit of parts as you have sensors already.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    I got a 4F0 910 283 F from ebay for £30, it supports 4 sensors + graphical support (sonar line display) ...
    I saw on a forum that it may also support rear view camera support but I did not retro fit that ...
    4F0 910 283 F also superseded to 4F0 910 283 N so I would assume that supports everything F does ...
    My car originally had a 4F0 910 283 - 4 sensors, no graphical support (sonar line display) ...
    From what I saw on a Russian forum :-
    4F0 910 283 A - 4 sensors, no graphical support
    4F0 910 283 B - 4 sensors, graphical support
    4F0 910 283 D - 4 sensors, graphical support
    4F0 910 283 F - 4 sensors, graphical support, rear view camera support
    I also saw a post were someone said that on parking aid modules which support 8 sensors and you only have 4 connected you can fool the module to work by using resistors in the non connected plug ...
    4F0 910 283 C - 8 sensors, graphical support
    4F0 910 283 E - 8 sensors, graphical support, rear view camera support
    4F0 910 283 G - 8 sensors, graphical support, rear view camera support
    4F0 910 283 H - 8 sensors, graphical support, rear view camera support
  1. Retro-Fit rear parking sensors
    By gaz j in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 6th November 2011, 19:43
  2. REAR PARKING SENSORS, whos had them retro-fitted ??????
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd September 2011, 23:48
  3. Has anyone retro fitted rear parking sensors to the S3?
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 22:06
  4. Fitting rear Parking Sensors?
    By zeratul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2008, 14:37
  5. Retro-fit rear parking sensors
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2005, 23:47
