Sky InsuranceEM Tuning
    roly
    Apr 2010
    Hindley, Wigan
    power tailgate switch
    Has anybody had a problem with the power tailgate switch? I can open from drivers door and external button but when I press the switch on the tailgate edge it doesn't close, to close I have to press the external button. It also looks that it is opening to far.
    Frustrated you bet.
    Erf
    Oct 2006
    Kingston
    234
    That does sound a bit frustrating. On the point about it opening too far, I had the opposite issue the other day, when all of a sudden the boot would only about about 20cm. I found that you can reset the opening height buy holding the boot to the desired opening height and holding the close button for about 7 secs. Not sure this will work for you if your close button isn't working though!
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    Apr 2012
    N. Wales, LL22
    1,224
    it can't open too far, does the switch light up?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    roly
    Apr 2010
    Hindley, Wigan
    Yes the close button is illuminated, when I say it opens too far I mean higher than normal.
  1. Fix Nearside Number Plate Light & Tailgate Switch
    By k1ano in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2012, 12:32
  2. Powered Tailgate Problem?
    By toastyhamster in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 1st September 2011, 20:15
  3. Avant 2010 Powered Tailgate
    By rosscotdi in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 26th March 2010, 00:11
  4. Can I tap CD changer outlet for switched radio power supply?
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th September 2006, 19:07
  5. Switched power source - problems
    By imported_Watson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2005, 00:12
