EM TuningMonster Motorsport
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By NotNormal
Thread: 3.0tdi Quattro auto fault code.....
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    72
    I keep getting this fault code coming up ..... Any help anyone ?
    symptoms are, driving in sport, progressive acceleration, 3rd to 4th and 4th to 5th, top end of the revs it rumbles/judders for a couple of seconds then sometimes drops into the next gear, sometime I have to back off the throttle then reapply to get it to engage the next gear
    I've had the box checked, the oil is of good quality and no water ingress - the oil level is satisfactory too
    trying to get a heads up here.....any help ?
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    72
    There are no other fault codes in the car either, nothing in the engine ecu ------ :/
    Ignore the age of the fault, this is an old picture i took - the fult has happen 5 or 6 times today on a run back from Blyton
    Jun 2011
    Great Melton Norfolk
    1,348
    its the gearbox ECU check the wiring /plugs as well.
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    72
    Quote Originally Posted by gen.heinz guderian View Post
    any hints on locations for the g/box ecu ?
    thanks
    tom
    Apr 2012
    N. Wales, LL22
    1,224
    under the floor?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Quote Originally Posted by NotNormal View Post
    It is in the transmission ... only accessible with the sump of gearbox removed ...
    You can access elec.harness on outside of gearbox ...
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    72
    Turns out it was an issue related to the fuel system
    Every two seconds after the low fuels pressure code flashed up the gearbox fault was logged
    Then the low fuel pressure fault vanished from the ecu
    The cars had a complete fuel system bar the tank and on fuel pipe as per a TPI from Audi - I've done 1000 + miles and its faultless
    the cars slightly better on fuel and the performance is back
    gupsterg likes this.
    gupsterg's Avatar
    Jun 2012
    279
    It wasn't anything related to coding
    Thanks for update ... happy ...
  1. Rampant front wheel spin in a quattro. No fault codes (VAG.COM). Any ideas?
    By TonyH50 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th October 2011, 20:37
  2. which would you choose: a6 3.0tdi quattro auto avant or bmw 535d touring
    By p1tse in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th July 2010, 00:16
  3. A3 2.0tdi BKD Fault codes :(
    By j50sho in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th July 2010, 15:06
  4. 3.0tdi quattro auto
    By p1tse in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th May 2010, 11:20
  5. 2000 A3 1.8T Quattro - Fault Codes
    By VaulterTim in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th July 2006, 00:54
