Badger5Volks Autos
Results 1 to 16 of 16
Like Tree14Likes
  • 5 Post By gupsterg
  • 4 Post By fishyfish
  • 2 Post By Tuddie
  • 1 Post By u4coffee
  • 1 Post By Kihltech
  • 1 Post By B5NUT
Thread: Rear wiper
    roly
    Apr 2010
    Hindley, Wigan
    Rear wiper
    My rear wiper today started working of it's own accord and eventually parking in varying positions, pushed stork on and off to no avail. I washed the Avant yesterday and now thinking if this has caused it - water ingress, although the car has been washed many times and this problem not showing up. Has anybody had this themselves and could it be water ingress. Thanks in advance - Roly
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    276
    Hi , one day my rear wiper stopped out of the blue ... it can also go nuts if washer fluid is leaking internally in motor (had that before as well) ...
    So here is my refurb info ... besides general tools a wiper arm puller is very handy, about a £5 from ebay ...
    So first the removal of lower trim... first I removed the emerg.triangle in compartment in tailgate trim... then the inner tail light covers...
    Hold on to these as once screws undone they fall quite easily...
    Next undo four torx screws on lower section of trim and two either side of emerg.triangle holder...
    Checked clearance of elec.harness to inner tail light... the red line highlight where issue could occur when removing trim IMO...
    Then unplug the lights in lower trim... place flat head in notch and lever out & unplug...
    The lower trim is held on by six trim clips....
    A wedge helped but considerable force is required to remove trim... you may need someone else to give a hand as trim falls when unclipped and if not careful could hit car and cause damage...
    Once removed you will see the motor...
    I unplugged washer hose marked by blue box, undid 5 torx screws on motor (one out of view on photo, denoted by red arrow)....
    I left the elec.cable plugged in to see when rear wiper engaged what happen... nothing moved so as I had once before solved an issue with internal leak of washer fluid in motor I thought why not take apart and try my own refurb...
    When you remove cover you will see this... do not lose the item in red box...
    ( guys I missed the original nasty shot when cover came off, above is the refurb'd photo, you will get an idea of how bad internals were from the photos below )
    Next was wiper arm removal, I removed the wiper arm nut cover... then the washer nozzle... then undid nut only to in line with inner nozzle... placed a flat metal object in between nozzle/nut and wiper arm removal tool... the metal object will help not to damage face of inner nozzle when removing arm ...
    I pushed inner nozzle from out side... I had closed tailgate so item would fall into boot space and not damage bumper...
    Look at that rust build up ... I could not move that with both hands what chance did the motor have
    You can see the PFTE tape used to seal internal point of nozzle with cover on my original repair of motor/leaks ...
    Inside of the motor cover ... the black square is where washer nozzle shaft seat internally...
    So I soaked nozzle/arm in WD40, then used needle files to remove rust from faces/teeth, gave blasts of WD40 to clean and repeated filing... then movement returned...
    Then cleaned up cover and nozzle/arm... and applied grease to both... the cover require grease due to the black item (red box item in earlier photo) on arm making contact with it...
    Then cut about 2 inch length of PFTE tape, fold in half along length, wound tight around end of nozzle/arm which meet cover...
    This was necessary on mine as due to wear (I think) on the washer hose attachment on metal cover not sealing properly on my motor...
    I do not believe nozzle/arm had seized/rusted due to another leak as all was dry inside wiper arm motor casing...
    I think on previous repair I missed opportunity of cleaning internals and greasing properly which was a year ago...
    Next I checked the elec.motor (this was not the issue with mine... it was the seized arm)... this was removed my undoing the two screws on housing and slowly twisting and lifting the grey cog up to allow motor to slide out... I cleaned and greased area under the grey cog...
    Below is what I call the bush housing/elec section for motor...
    These where the bushes for the motor...
    Surprisingly the broken bushes still worked in motor when I refitted them... it was a case of locating them in the elec.section then using a sleeve to keep them in place as I put the motor shaft in place... the pressure of the spring mounts for the bushes kept them in place ...
    The refurb'd parts fitted and tested before cover go back on...
    It is best to run motor without wiper arm on first, so shaft/motor rotate to appropriate positions of start/stop...
    I placed my finger on grey cog as from movement/lack of cover the wiper arm shaft and grey cog move outwards when motor initiate if no pressure applied...
    Some maybe wondering why bother... well my view if you know method fix is probably an hours work and sorting seized arm pretty easy... the elec.motor section was me just meddling around
    The motor range from £80-£100 plus fitting if you not do yourself... so in my view worth the effort...
    So what I've learnt from meddling twice with rear wiper motor:-
    i) if water leaking inside motor small application of PFTE tape on washer shaft
    ii) if wiper arm not rotating check to see if inner arm mechanism seized
    iii) lack of water or pressure check pipework running from reservoir to washer motor, cap secure on reservoir
    iv) check nozzle jets clear which on wiper arm
    B5NUT, PAULF, fishyfish and 2 others like this.
    Apr 2012
    Oxford
    126
    gups, I am always gobsmacked by the effort you put into your "how to" posts... you are a real asset to this forum (and that other one that you frequent).
    By this stage, whatever you don't know about taking apart and fixing a C6 isn't worth knowing!
    gupsterg, Tuddie, PODA3 and 1 others like this.
    gupsterg's Avatar
    Jun 2012
    276
    Thanks mate ...
    We all count ...
    Tuddie's Avatar
    Nov 2012
    Ayrshire
    114
    Absolutely brilliant write up, its of no use to me but im sure it will be very helpfull to many others so this is just a thank you post as people like you make this forum worth visiting.
    gupsterg and PODA3 like this.
    My cars:
    2013 BMW 535d M-Sport Alpine White
    2004 Lancer Evolution 8MR FQ-340 Palma Red
    gupsterg's Avatar
    Jun 2012
    276
    Cheers mate you ...
    You guys are making me ...
    roly
    Apr 2010
    Hindley, Wigan
    Gupsterg - wow that's a detailed reply, hopefully at the weekend - weather permitting I will take a look. It is probably the seal which needs PTFE but might strip out and clean all components. Again thanks for the info - Roly
    gupsterg likes this.
    gupsterg's Avatar
    Jun 2012
    276
    No worries mate ...
    The only tool I'd recommend getting is a wiper arm removal tool ... I got an el cheapo one from ebay for under a fiver IIRC ...
    May 2014
    Quote Originally Posted by gupsterg View Post
    Many thanks to this guide!
    I almost had a panic removing the trim, that is trying to remove the trim. I just could not get the trim closest to the window loose, breaking a bunch of clips and plastic details in the progress.
    This is what did it for me:
    1. Stand behind the car
    2. Make sure the trim is loose enough that all six clips are out
    3. Support the entire trim with the fore arms
    4. Follow the side of the window trim and insert fingers between the trim and the window, just next to the overlap to the side trim.
    5. Un-hook the rear trim from the side trim by lifting it out from the window with the fingers, as shown below. (There is a kind of hook in the rear trim that prevents it from being lifted. Unfortunately I forgot to take a picture of it.)
    Update: Here is the part number for the wiper motor to ease Ebay hunting
    4F9955711B
    Last edited by Kihltech; 11th May 2014 at 09:19. Reason: Added original part number
    Jul 2013
    24
    Any idea what the difference is between 4F9955711A, 4F9955711B, and 4F9955711C? I've seen all three on eBay.
    2,152
    Both A and B revisions will fit the A6 the C revision only fits the A4
    Jul 2013
    24
    Legend thanks!
    2,152
    Should also add the A revision does not fit the facelift C6 model, your best bet would be the B revision.
    Andi's Avatar
    Jun 2012
    London, UK
    17
    What about if your rear wiper has gone a bit "floppy"? Mine works perfectly, but at rest now hangs a little below the glass line on the body work and has a lot of play in it..
    /// Andi :: 2010 A6 Avant V6 3.0 TDI Le Mans in Phantom Black
    .: VCDS Mods: VIM, Needle Sweep, Passenger Mirror Dip, Oil Temp with Lap timer, APS+ enabled
    2,152
    Most likely some of the teeth have been worn away, best bet is to follow the write-up by gupsterg and check it over.
    gupsterg's Avatar
    Jun 2012
    276
    Quote Originally Posted by Andi View Post
    Mine has some play and was "floppy", on investigation the play right at the shaft is low but as you view it further along the length the play is bigger. I wish I could term this in a better way!LOL
    All I did was move wiper arm to the end of play, remove it, then replaced on shaft at point where it is not on bodywork. When I ran wiper it didn't seem to overrun on to bodywork either side.
    Service manual suggests 27mm gap between tip of wiper and bottom edge of glass.
    Hope that helps.
    Gup
  1. Rear Wiper Jet
    By Stepho in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2004, 10:15
  2. rear wiper
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2004, 23:49
  3. rear wiper stuck
    By Haris in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2004, 15:44
  4. Stuttering rear wiper
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2003, 22:15
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
