AH FabricationsBadger5
    Molnboman's Avatar
    A6 2.0T FSI Advice
    Hello, wondering if anyone can give me a bit of feedback. Am looking to upsize to the A6 Avant ( 2007 - 2008 vintage ) and was wondering if anyone has the 2.0t avant and could tell me what it was like drive wise in comparison to equivalent A4 with the same engine. Is there anything I should be looking out for? I have been very lucky with my current 2.0t bgb engined A4 avant, although I know they sometimes can be troublesome. Any advice or links to similar questions / answers would be greatly appreciated.
    A
    Molnboman's Avatar
    Just giving this a Bump c'mon A6 owners....someone must have some knowledge with sharing!
    A
    Aug 2009
    200
    Quote Originally Posted by Molnboman View Post
    A
    I think the problem you have here, is that compared to the Diesel there were only a handful of 2.0TFSI A6's sold to the point where there is no C7 2.0 petrol version sold. Sorry not to be of more help. Ignoring the engine the earlier C6 Avant's had a problem with the rear washer leaking. It either split in the rear LH pillar causing water to end up all over the MMI modules which are located behind the LH trim in the boot, or under the floor in the front passenger footwell, causing the CCM module (which handles central locking amongst other things) to fail. This is well documented on various forums but you should check that all of the MMI features work as intended and that there is no sign of water ingress behind the panel in the boot and also that the front passenger carpet is dry. Also check after using the rear washer and that it works with good pressure. Low pressure would suggest a leak
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
  1. newbie just bought A3 T fsi dsg 2006....advice please
    By jondsg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2013, 18:53
  2. 2004 2.0 fsi wont start advice..plus a few other questions
    By dk1234 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th January 2012, 21:58
  3. A3 -55 2.0 fsi new buyer advice please
    By ajex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2011, 20:03
  4. 2.0 T FSI Buying Advice
    By bench33 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2011, 01:54
  5. 1.4 T FSi - HELP & ADVICE
    By samil87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2010, 15:38
