EM TuningSky Insurance
    Aug 2012
    77
    Transmission Fluid for 07 3.0 TDi Quattro Tip - Price comparison
    I did a search on ATF fluid and transmission fluid without much success so thought it would be a good idea to have a single thread listing compatible/correct ATF to use for tiptronic boxes.
    As we know Audi main dealers & specialists charge anything from £25-£33 per liter which (many feel) is a little bit of a rip off. Also some places (and posts) state anything between 5-9 liters to refill once tranny sump removed. Note it should be the higher number if the filter/strainer is removed at the same time:
    Audi main Stealer
    £32.88 inc VAT per liter (Shell M.1375.4/Lifeguard 6) £295.92
    £76.06 inc Vat filter/strainer/gasket (£37.73 of which is just the rubber gasket!!)
    £371.98 inc VAT total
    Bristol Transmissions
    £15.60 inc VAT per liter Lifeguard 6
    £50.40 inc Vat filter/strainer/gasket (part no BTL2028)
    £190.80 inc VAT total
    Total saving of £181.18 in parts alone!
    Annoyingly I have 10l of Esso LT 171141 (for my Jaguar) in my garage which is effectively Lifeguard 5 which I've been told isn't compatible...boo hoo hiss!!
    So anyone found anywhere cheaper for the parts?
    Apr 2012
    Oxford
    126
    From what I have been told by a local transmission shop and my local VAG indie, you can never manage to change all the fluid, even if you drop the pan, as there is no way to drain the torque converter, so 5-6 litres may actually be closer the mark.
    That said, that is a pretty good price for the bits from Bristol Transmissions... I was quoted about 300-ish plus 50 quid labour by the auto transmission guys nearest me, so I may be up for a jaunt to Bristol instead
    Aug 2012
    77
    Fishy, you're right in about 99% of cases, however there are some transmission places that have the facility to pump new fluid through the torque converter effectively purging it of all old oil...when it runs clean they then stop.
    Bristol don't have this but will do the standard job for £280 inc parts/labour/VAT
    Apr 2012
    N. Wales, LL22
    1,224
    how often should the fluid be changed?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Aug 2012
    77
    ZF say every 80k miles, however if you've bought yours 2nd hand you'll not be aware of how it was used and any problems
    For example:
    If it has a towbar it's logical to assume it's been used to tow, if so they say every 30k miles if half of that has been towing
    If the engine has overheated in the past it can 'cook' the tranny fluid and should immediately be changed (was the case in my Jag where engine overheating defo cooked the tranny fluid). Unsure if this applies to the A6 as haven't spent any time under it to know how close individual components are.
    Am doing mine as soon as am flush (PI)
  1. DPF Delete for a 170 TDI Quattro Help?
    By MOOSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2011, 18:42
  2. what oil do you use for a 170 tdi quattro
    By gaz4410 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th February 2011, 12:32
  3. Tuning A6 3.0 TDi Quattro Tip
    By NalA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th November 2006, 17:17
  4. A4 TDI QUATTRO FOR SALE
    By eimajmong in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th August 2006, 18:30
  5. How many Litres for Transmission Fluid?
    By javakid47 in forum Classic Audi Forum
    Last Post: 13th January 2005, 20:26
