EM TuningMonster Motorsport
    Aug 2012
    77
    Best brake pads for my 07 salon 3.0TDi Quattro tip 233
    Will need to get these done this year, in the past I've used:
    Hawk - Good
    Pagid - OEM
    EBC - Low dust but OEM standard performance
    Akebono - low dust and high performance
    These were all on my Jag XK8
    What would you recommend for a my Audi...did a search of the forum and found surprisingly little
    Also brake disc recommendations, grooved/dimpled etc?
    Jul 2009
    16
    I had this model before my present S6. Personally I would stick with OEM all the way!
    I thought I need better brakes and switched to Tarox drilled/grooved discs with OEM pads and they were noisey as hell! In hindsight there was nothing really wrong with my OEM discs but as I drove the car irregularly I mistook underused brake disc contamination for warping so changed them. What they really needed was buffing up a bit!
    If you really need new discs and want a better material consider a plane disc. Brembo I believe do a plane disc for this car.
    As far as brake pads go the Ferodo DS 2500 series I think are the best you could get, of course they may squeal a bit, not always just 'may'.
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    I just used Genuine on mine and i cant say i can fault them.
    V8 baby... oh yeah
    Jan 2011
    northants
    165
    jurid pads are good low cost
    performance friction/ferodo ds2500 good high cost
    disc wise i only fit jurid/brembo aftermarket or genuine
    Aug 2012
    77
    Thanks for the replies guys, will stick to OEM pads then, should keep the cost down too, local VAG specialist only charges £40 an hour labour so won't be too expensive and may be able to do the lot in under an hour. May also get them to fit my mudflaps since they'll have the wheels off anyway! :O)
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    I used PAGID all round pads & discs, DIY install... done over 10K miles on them no issues...
    As good or same as the genuine Audi ones they replaced...
    PAGID, MINTEX, TEXTAR, all the same company... TMC Friction ....
    Have a google some VAG vehicles have any of those plus a VAG stamp out of the factory...
  1. Best brakes pads for S3 2007?
    By NME in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2011, 10:15
  2. New brake pads for A6 Avant 2.5 V6 TDI Sport
    By fjtwelve in forum Handling
    Last Post: 13th April 2010, 15:46
  3. Best brake pads for keeping rims clean
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2008, 00:13
  4. Where to buy oem or equivalent brake pads for 1.8T
    By imported_Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2006, 09:47
  5. WHICH BRAKE PADS FOR S3??
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 07:59
