Chris NottAH Fabrications
Results 1 to 12 of 12
    Dec 2012
    25
    Confusing tyre pressures
    Hello,
    i am confused with the recommended tyre pressures for my allroad. The label inside the fuel cap says 33 front and 30 rear for light loads and 39 front and 42 rear for heavy loads. The handbook says audi recommend running on heavy load figures for for economy.
    i am worried that i may prematurely wear out the tyres on the heavy load as I don't carry a heavy load regularly. The light load figures also seem very low for such a heavy car.
    my wheels are 17" with 225/55/17.
    amy view would be welcomed. I have scoured the Internet to no avail.
    Audi Dynamik's Avatar
    Sep 2011
    2,121
    If you have a heavy load then put in the higher pressure, if not then put in the lower pressure.
    If you don't carry a heavy load regularly then if i were you i would but the light load pressure in.
    There will not be a noticeable difference in economy tbh.
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    Dec 2012
    25
    Thanks, I will run the lower rating then. It does seem low for such a heavy car do you not think?
    Sep 2011
    2,121
    Yeah it does actually it is probably down to your tyre size, i don't know mine from the top of my head but i know the rear for my 255/35/19 is 33 low pressure because i got a nail in the thing yesterday which cant be repaired, i need some new tyres soon anyway so i will have 4 new Dunlops on Saturday.
    Dec 2012
    25
    Thanks, had Dunlop sports on mine, bought some uniroyal Rainsport 2s for it. Hope they are good.
    Aug 2012
    77
    I've had Uniroyal Rainsport 2's on my Jag XK8 and have to say the best tyre I've ever had on them in 8yrs, no lit whatsoever in the wet and I think they com with 9mm of tread from new.
    Sidewalls are a little flimsy though and ripped two of mine mounting kerbs...slowly
    Dec 2012
    25
    Quote Originally Posted by MarkyM View Post
    i have read that the sidewall are flimsy. Mine are 101 XL rated, hopefully that will mean they are slightly stiffer and less prone to tearing.
    Aug 2012
    77
    Mine were 101XL's too, two of them caught a curb (at the same time!) and blew on me was at low speed too (less than 15MPH) that was a complete pain. Easily overcome by the benefits of this typically soggy British weather :O)
    Dec 2012
    25
    you are just the person I need to ask advice from. Do I need to run the XL tyres at a higher pressure than a standard tyre? My car requires 33psi front and 30 at the rear for a light load. Some people on forums say that XL tyres would need to be run at a higher psi than a standard tyre. I personally think this is wrong and that the advantage of an XL tyre is that it can take higher pressures in order to then carry heavier loads.
    what do you think?
    Aug 2012
    77
    Duggy it's a very 'suck it and see' thing, extra load tyres for example wouldn't be used in a Aygo/smart/C1 running at full load, they're usually reserved for cars with a pretty impressive curb weight
    At times when I've run Extra load at max inflation for a few thousand miles (e.g. a house move) I've found that the tyre centres wear atrociously which is a clear sign of over inflation. By the same token I have winter tyres on my A6 at the mo...temps are mainly below 7.5 and they're not XL's but I run those at standard inflation as the harder compound can take it.
    The best method for me is checking the tyres for uneven wear every 500-1000 miles or so and adjusting pressures accordingly. I find this artical useful.
    Tire Tech Information - Tire Specs Explained: Maximum Load
    Apr 2012
    N. Wales, LL22
    1,224
    Quote Originally Posted by Duggy72 View Post
    what do you think?
    i think you should post a pic of your tyre sticker
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Dec 2012
    25
    Mark,
    thanks for the advice and the link. The link confirms my theory that the XL tyre needs only to be run at higher pressure if a heavy load is going to be used.
    there are some very confusing theories on other forums saying that if my car was on standard tyres a light load would be 33 front and 30 rear, but the same light load on XL tyres would require higher pressures to achieve the same load capacity. The link you sent disproves that.
    thanks very much mate.
  1. A3 3.2 tyre pressures
    By GARTHY in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 11:04
  2. tyre pressures
    By carl310166 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2004, 15:46
  3. Tyre pressures
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2004, 08:39
  4. TYRE PRESSURES
    By wezhaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 08:06
  5. Optimum Tyre pressures
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2003, 13:37
