Chris NottAH Fabrications
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By gupsterg
Thread: A6 C6 Rear LED light conversion
    Mar 2013
    7
    HELP HELP !!!
    I just bought an A6 which has had the rear lights replaced with 2010 model LED's by some maniac who has butcher and ruined the wire harness. The wiring has had both the rear light units and wiring harness plugs cut off so i don't know what goes where. I know it's a lot to ask but would anyone be prepared to look at there own car and list which wire goes to what light or connection. I have tried to get a wiring diagram and have been to lots of garages and a couple of auto electricians but no one seems to beable to help without the info. Until i get this i can't use the car. Please if you can help i would be very grateful. Thanks for listening.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    259
    Hi,
    i) What year is your car?
    ii) Saloon or Avant?
    Regards
    G
    Mar 2013
    7
    Quote Originally Posted by gupsterg View Post
    Hi,
    Regards
    G
    The Car is October 2004 and it's a saloon 2.4 V6 petrol.
    Thanks for your response.
    gupsterg's Avatar
    Jun 2012
    259
    Will have nose at stuff tomorrow if find anything useful will post/PM ...
    gupsterg's Avatar
    Jun 2012
    259
    Hi,
    Information has been prepared... I will need an external email to send... please PM ...
    The format it is in will be quicker for me to give plus may be easier for you to follow...
    Regards
    G
    Tuddie likes this.
    Mar 2013
    7
    Hi,
    Regards
    G
    my email is adejeg@aol.com. I look forward to you email.
    Regards jeffers257
    gupsterg's Avatar
    Jun 2012
    259
    Hi,
    Email has been sent... Lowline is standard rear lights... Highline is the factory fit LED tail lights...
    Hope it helps... T10x/x is what you need to ref as that as the plug which go into the taillight unit...
    ATB
    G
    Tay
    May 2012
    Warrington
    321
    Out of curiosity, where did you buy the car from? I did a bit of VCDS coding for a guy who had carried out this LED upgrade, and it turned out he had bodged all the wires. It sounds like that same guy :/
    Mar 2013
    7
    The car came from Bramhall, Cheshire. I have wired the lights now but i am still having trouble with a cople of things. Do you know anything that might be helpful to eradicate the gremlins ? Shoot me an email to address in the previous posts and maybe we can chat ?
    Regards
    Apr 2012
    N. Wales, LL22
    1,224
    has it had the bootlid, bumper etc swapped too?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Mar 2013
    7
    Long time getting back to you but I have been working overseas and only just picked up your message. The boot lid and bumper have been replaced and I am going to try to sort the gremlins out now.
    gupsterg's Avatar
    Jun 2012
    259
    So you have a prefacelift A6 (2004 - 2009) with facelift (2009-2011) tail lights, boot lid, etc, etc ?
    Mar 2013
    7
    yes that's correct. The lights in the boot lid are fine but the tail lights seem to have an intermittent fault. I have new rear lights to fit but I am not sure if the fault is because I have done something wrong previously. Do you know if you have to reduce the voltage or wattage as the LED's use less power or is it just a straight fit. The other thing is correcting the error codes that appear on the dash. I was told to go into the ECU and reset to highline, however using Vagcom it just says unable to connect. I was thinking of using some 5w 30ohm resistors for the rear lights and 21watt 30 ohm for the brake light and rear fog light. Do you think that would work or does anyone make or sell a plug and play unit to simply fit.
    Thanks Geoff
    Mar 2014
    A6 c6 rear facelift light conversion.
    Hi,
    i have recently brought an audi a6 lemans 3.0 quattro and just had the rear facelifted ....
    im looking for help with the wiring of the rear led lights.
    The plugs are diffrent and i have been told i need to change a module.
    Thanks .
    Mar 2013
    7
    Quote Originally Posted by F8rgd View Post
    Hi,
    Thanks .
    send me your email address and i'll forward all the info and wiring diagrams I have. You won't need to change the lighting module just re code it.
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,991
  1. Difference with these rear LED lights...??
    By nad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th July 2011, 17:24
  2. Aftermarket rear led lights! Has anyone used these?
    By HenriEST in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th February 2011, 21:11
  3. JOM rear led lights
    By geron in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th September 2010, 10:01
  4. Rear LED lights
    By TOON FLYER in forum Parts Requests
    Last Post: 6th May 2010, 21:20
  5. New Style Rear LED Lights/ sidelight bulb replacing
    By gazzaw888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2010, 22:14
