    ZYX
    Nov 2012
    22
    Help - Non Starter :(
    Hey Everyone,
    A bit of an unusual problem with my 04 C6 3.0 Tdi Quattro for you Audi Experts...
    The problem is that the car won't even crank over !
    I put the key in , wait for the glow plug light to go off and turn the key to nothing , won't even turn over or attempt to start...
    Anyone ever expierence this before or know anything that could be wrong ??
    Any help would be greatly appreciated , Sean.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    I've experienced this on mine a few times... usually it is the key at fault... I take it apart and reseat stuff then AOK...
    Have you a spare key try it... other than that a VCDS scan may help...
    ZYX
    Nov 2012
    22
    Thanks very much, yeah I have a spare key.
    I will check the current one too.
    I hope it works !
    Will update the thread later , fingers crossed !
    Sean.
    ZYX
    Nov 2012
    22
    Unfortunately it's a negative, car failed to start....
    Suppose the next step is to strip back the plastic undercarriage beneath the car, locate the starter and see if she is getting power.....
    I'll be busy the weekend !
    gupsterg's Avatar
    Jun 2012
    279
    Hi,
    You may wish to get a forum member to do a VCDS scan for you...
    A map is located in this section... Link:- VCDS (formerly VAG-COM) forum
    ATB
    G
    ZYX
    Nov 2012
    22
    Thanks for that G.
    Turns out it was a sticky / worn out Starter motor. It was getting 12V with ignition on and it was getting its 12V to fire up when the key was turned to start. Still wouldn't start so I bridged the permanent 12V to crank the starter motor for a second and got a response.
    Plugged back in the harness and she Fired up !
    Have tried it several times since and the motor has been struggling a bit with jerking and split second pauses whilst turning over, but it has started. So I'm gonna pull it out and get it reconditioned as it could potentially fail anywhere.
    I'm happy enough that was the problem.
    Thanks for all the Help.
    Sean.
  1. 2000 Sport TDI - Non Starter - Please help before it burns !!!!
    By ruffrida in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2012, 14:20
  2. help non starter
    By ratlook in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th October 2011, 23:17
  3. A3 TDi DPF / ESP Error Non Starter??? HELP
    By Indie_DSG in forum Diesel forum
    Last Post: 18th June 2009, 11:34
  4. help A6 allroad - non starter !!!
    By TDI180 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th January 2009, 17:52
  5. A4 tdi 110 non starter HELP!
    By bigmaddog in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd April 2007, 10:16
