AH FabricationsSky Insurance
    Sep 2010
    Teesside
    31
    gearbox bearings?
    Just wondering if anyone has experienced worn bearings in a c6 manual 6 speed gearbox, from what I've read it was a common issue on the earlier A6 but haven't come across any complaints on these newer ones.
    I had the front wheel bearings changed a year ago thinking it was one of them but the noise has progressively got worse since then, I have changed the discs and pads incase it was these but no different, I have noticed that the passenger side inner cv joint has is worn and has a little play in it but not sure that would give the same noise as a worn bearing.
    My car is a 2005 2.4 if this makes any difference.
    Sep 2010
    Teesside
    31
    anyone had gearbox bearing problems?
  1. changing the gearbox oil
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 06:14
  2. S3 Gearbox Oil for ridding Notchiness
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2003, 22:24
  3. Sequential Gearbox Anyone?
    By AL_B in forum General Technical / How To
    Last Post: 21st February 2003, 12:58
  4. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
  5. DSG auto gearbox... confirmed?
    By jamesa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2003, 14:21
