Volks AutosEM Tuning
    Jul 2009
    16
    S6 V10 - handling upgrade ideas?
    It's not that there's anything wrong with the suspension, I am sure it's doing what the factory designed it to but...
    It's a bit hard/bouncy over some of the tighter and "lumpier" roads near us. It's not like it's going to loose traction (heavens no!) but it doesn't inspire confidence.
    I have this idea that one or both of the two following things may improve matters:
    1) These KWS coilovers with adjustable rebound/compression - properly set up.
    KW coilover Variant 3 /// With adjustable compression and rebound dampening.
    2) Decent lightweight alloy wheels. Although I don't know how much the standard Audi fitments weigh just yet.
    Any thoughts, perhaps I'm asking too much?
    Avantageous
    Apr 2010
    Hampshire
    337
    I'd say either those KW V3's, or Koni FSDs w/ H&R Springs. The Koni/H&R option would be cheaper, and you could spend the rest on a set of H&R front and rear anti rollbars. That's what I would do. I would only go for the KW's if you want to lower the car much further than stock. The H&R springs should give you something like a 10mm drop (I think, don't quote me on that), which doesn't sound like a lot but would make a huge difference to the way it looks.
    2011 Audi-Sport.net Fantasy Formula 1 Champion
    2005 Audi A6 3.2FSI S-Line Quattro Stratos Blue
    19x9 S6 / Half Leather Interior / Memory Seats / Black Headlining / S6 Paddle Wheel / S6 Exhaust
    Front & Rear Parking Sensors / TPMS / Adaptive Xenons / Actuated Boot Lid / Bose / Sat Nav / Bluetooth / Sunroof
    Double Glazing / Auto Dimming Interior & Exterior Folding Mirrors / Storage Pack / Lighting Pack
    May 2008
    Bedfordshire
    137
    H&R do a 15/20mm kit which is an improvement but not massive and relatively inexpensive.
    KW do an adjustable spring kit (no shocks) which knocks off about 40mm at its "highest" setting, or you go for a fuly adjustable kit for more outlay, coupled with ARBs for tighter handling.
    The standard set up is not great, hard ride, crashy at times and average handling.
    Jun 2008
    45
    Are the eibachs any good?
    May 2008
    Bedfordshire
    137
    I'd say H&R and Eibach are on par
  1. B7 tdi 3.0 Quattro - handling upgrade?
    By daveyb0y in forum DPM Performance
    Last Post: 7th March 2012, 09:44
  2. Speaker upgrade ideas
    By Oberon in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 19th January 2012, 10:48
  3. Replies: 3
    Last Post: 29th January 2011, 11:43
  4. Rear speaker upgrade ideas..?
    By bogo in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2010, 07:38
  5. Handling upgrade 2.5V6TDIQ
    By RadCap in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2009, 18:14
