Volks AutosSky Insurance
Results 1 to 7 of 7
    Nov 2008
    Faulty Xenon on '07 S-line Avant
    The nearside xenon headlight on my 07 plate A6 2.7Tdi Avant S-line has gone intermittant. It works 9 times out of 10 but every few days it fails to light and i get a dash warning. Switching it off and on brings it back on. I have checked that the bulb really is not lighting and it isn't just a faulty error message.
    Has anyone alse seen that before ? If I need to replace it I know it isn't going to be easy. I found some instructions in an A4 forum for replacing the xenon bulb by removing the water reservoir and power steering reservoir. Is that going to work on an A6 ?
    Thanks in advance for any advice.
    Jun 2011
    Wellingborough
    1,133
    Easier if you remove the bumper and take the headlamp out, the d2s bulbs are a real pita to fit so if its off the car it will be alot quiker.
    The bulbs can go, i had a customer who had an 09 with a bulb out.
    i can supply you a pair of uprated bulbs so you can change both to a nice white colour.
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Nov 2008
    It's all been OK for few months but suddenly its got dramatically worse.
    The offside one has just totally failed. I noticed it was a soft pink a few days ago and now and doesn't come on at all.
    The nearside one comes on fine when the car is cold and stays on for hours, no problem. However if I leave it on for a while ( 10-30 mins) and switch it off then on again when it's warm it doesn't come back on.
    Question. Is there any way I can tell if my problem(s) are ballast or bulb. Do I just have to purchase both and spend time swapping them in and out ?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,734
    Sounds more like a bulb problem, I think a ballast will either work, or not.
    1,889
    If you want to know if it's the ballast take the no-working side bulb and put it in the working headlight, if you get the same result then you know where the fault lies.
    Nov 2008
    Ok. We have an answer.
    I've replaced the bulbs on both sides and all seems OK.
    Thanks to all for your helpful answers
    1,889
    How much were replacement bulbs, I know I'm going to need to change mine at some point.
  1. a4 3.0 tdi s-line avant tyre pressures
    By aldo286 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th July 2007, 08:35
  2. S Line Avant Towbar
    By Mini Type R in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th March 2007, 17:24
  3. S-Line Avant boot spoiler?
    By FrankG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th August 2006, 10:04
  4. S line avant photos
    By trekbiker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2005, 19:25
  5. A4 S-line Avant problem is........
    By Mcgough in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st December 2004, 22:11
