Volks AutosAWEsome GTI
    Nov 2012
    Replacing electronic parking brake switch '07 A6
    Has anyone replaced the electronic parking brake switch on their A6 - C6? Mine works fine, but its peeling and looks crappy. Especially since the rest of the trim is still so perfect!
    I found the part# 4F1-927-225-C direct replacement.
    (I also found a newer switch with a chrome-strip edge, part# 4E1-927-225-B - though I don't think that would fit since the hardware looks different from the direct replacement).
    Any instructions on how to replace this switch?
    Thanks all!
    Und'un.
    Avantageous
    Apr 2010
    Hampshire
    329
    You can use the newer chrome tipped switch, it's a straight swap, I've done mine.
    As for removing it, it's a real *****! You need to remove the entire centre console!
    First you pop off the sides, undo a load of screws, remove the ashtray and undo more screws, remove the AC unit, remove rear vent, undo bolt that holds armrest, remove armrest, undo screw under rubber mat, and then disconnect the wiring.
    Its definately not a job I want to do again! But I have to, because I forgot to reconnect the cigarette lighter!
    2011 Audi-Sport.net Fantasy Formula 1 Champion
    2005 Audi A6 3.2FSI S-Line Quattro Stratos Blue
    19x9 S6 / Half Leather Interior / Memory Seats / Black Headlining / S6 Paddle Wheel / S6 Exhaust
    Front & Rear Parking Sensors / TPMS / Adaptive Xenons / Actuated Boot Lid / Bose / Sat Nav / Bluetooth / Sunroof
    Double Glazing / Auto Dimming Interior & Exterior Folding Mirrors / Storage Pack / Lighting Pack
    Nov 2012
    Thanks!! Maybe I need help with this...sounds like a mega job :-(
    Quote Originally Posted by ChrisFurlong View Post
  1. A6 3.0TDi Auto Electronic Parking Brake
    By mattyn in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 11th April 2012, 23:05
  2. ESP light and ABS on after brake switch is replaced
    By polar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th January 2011, 14:54
  3. Brake switch problems
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2008, 21:10
  4. Pic request - Front parking sensor switch
    By JohnS3 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th December 2007, 17:40
  5. Warning lights - the ABS and the parking brake light
    By vij31 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th March 2006, 16:10
Tags for this Thread
