Monster MotorsportEM Tuning
Results 1 to 7 of 7
    Nov 2012
    bristol
    MMI failed on 2007 A6 avant
    I need some help as my MMI has failed due to water ingress (rear washer) in the rear n/s panel soaking the Bose amplifier. (have upgraded music in my 2.7Tdi Avant S line 2007). I dried it out and it worked for a while but bit by bit the volume, radio, screen, blue tooth etc started to fail. Now nothing works.
    Have tried to find a replacement amp but to no avail, (£1000 for a new one +++?) Some say even if you find one it won't work as it needs coding by Audi?
    I understand this is a known (design) problem DSC01090.JPGand in certain cases Audi have admitted fault & repaired/replaced?
    Has anyone out there had a similar experience? Any suggestions how I can approach this please .......
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    You'll have to push main dealer hard... highlight things like:- i) future servicing ii) future purchasing... lay it on thick!
    Seen a thread on another forum where someone got FOC amp...
    Will PM you link... otherwise maybe find AMP on ebay.de or breaking car... not sure if "Component Protection" is something you going to hit besides coding... there is a garage in Harrow which remove CP for about £60 Link:- Diagnostic equipment of Audi VW Specialists Centre in London
    Oct 2012
    Yatton
    156
    sorry to hear this mate you must be gutted I know I would be. Hope you get it sorted. I know of a good mobile Radio fitter actually he does alot more than that and he knows is stuff but wont charge the earth he's not to far away from you either based in weston super mare. Tel 07880846873
    Give him a try he'll be happy to help if he can.
    Dec 2012
    13
    Call your local Audi centre and get them to check for re-calls this was a recall on certain models.
    Nov 2012
    bristol
    thank you very much for your help, see my message below, Nick
    Nov 2012
    bristol
    The latest is Audi dealer wants £3300 to replace the lot (Bose, Radio & Sat Nav) as they say just replacing one could blow the lot. Yes, there is a recall on the rear washer (leaking into the tailgate & potentially wrecking the electronics) but not a "safety issue" so they don't bother to tell owners! Such bull****!
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Most of that can be picked up off ebay for less than £1000, but before you replace the lot as they say, just bypass each module until you identify the failing module, usually the amp as that's on the top, you would be very unlucky for all 3 to be damaged. Pity your so far away or I could have sorted it for you.
  1. A4 2.0tdi 170 2007 quattro avant
    By subsea99 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th May 2012, 20:11
  2. Questions about Basic MMi on C6 (2007)
    By G4JSG in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th September 2011, 12:18
  3. A6 avant 07 satnav MMI system
    By AustinM in forum Satellite Navigation
    Last Post: 9th February 2011, 15:20
  4. 2007 AUDI A6 AVANT BOOT PANEL REMOVAL
    By nigel1955 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd November 2009, 13:01
  5. 2007 A6 Avant rear parking brake
    By bdub in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd May 2009, 22:57
