Volks AutosEM Tuning
Results 1 to 8 of 8
    Oct 2009
    London
    79
    MMI/Multi CD changer issue
    Guys
    I can't eject the CD in the multi changer in the glove box - (the CD was included in the purchase a couple of weeks ago - I realise why now!!!) The unit looks like it's going to eject but gives up and plays the disc instead....
    I can see that there are a couple of slots at the base of the unit in the glove box - I'm assuming that these are to release the whole unit? Is this repairable or am I looking at a new CD changer?
    I'm not really an in-car CD man but will look to integrate my iPod instead (but that's for another post on here)
    Jan 2012
    1,601
    If you have MMI high it's a straight swap for the Audi music interface unit and yes you need the two removal keys to pull the unit.
    Oct 2009
    London
    79
    Looks a bit pricey for a replacement unit
    I'm not sure which version MMI I have :?
    Mine is the full colour screen with SATNAV
    My car is a 57 plate A6 S Line Avant if that helps.....
    As I'm only after iPod use, will this cable do the job:
    iPod/iPhone 3G S/4/4S Audio Interface AMI Cable for Audi A3 A4 A5 A6 A8 TT Q5 Q7 | eBay
    Thanks again
    Aug 2009
    182
    Quote Originally Posted by linners View Post
    Thanks again
    No, because you need the AMI unit in order to use this cable and it is unlikely based on age that your car has that (worth checking to see if there is a socket in the roof of the glovebox, if there is then you have AMI and all you need is the cable. If not and as you have the 2G MMI High system you will need something like this Audi Music Interface AMI A4 A5 A6 A8 Q5 Q7 COMPLETE RETROFIT INSTALL KIT NEW !!! | eBay. If you are happy to lose the CD Unit then it should be a straight swap. If you want both then it is rather more involved. You may also need to upgrade the MMI software version to support the AMI (I believe v5570 is the most recent for cars with 2G MMI)
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    Oct 2009
    London
    79
    Damn!
    Is there a 3.5mm adaptor that I can connect to this without using the MMI functionality, ie. use the controls on the iPod itself (or any other 3.5mm output source)?
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    255
    Press "Car".... then select "Settings"... then select "Version"... below photo underlined is my MMI version...
    If you want to update your MMI firmware you must do that before you get shot of CD changer as update at home is via CD...
    Is there a 3.5mm adaptor that I can connect to this...
    If you mean to AMI yes 3.5mm cable available... without AMI MMI have no AUX input... another route... Link:- Dension Homepage
    Some rate Dension other's not... I prefer AMI... but if you have no bluetooth Dension is easier retro to get AUX input/BT...
    Oct 2009
    London
    79
    Thanks Gupsterg - looks like I'll have to do the AMI upgrade at some point to get what I want from the system. I might even see if I can fiddle around and try and service the CD changer
    In the meantime, and far from ideal, anyone on here have any experience of FM transmitters such as this:
    Belkin CarAudio Connect FM: Amazon.co.uk: Electronics=
    (There's so much sh*t on the radio these days!!!)
    TIA
    Aug 2009
    182
    TIA
    No experience of that device but I have used a previous version of this device Griffin Roadtrip for iPhone and iPod with SmartScan FM: Amazon.co.uk: Electronics which has the advantage of no wires and it charges you "iDevice" at the same time. Worked well. Only issue with all of these devices is that as you drive around the country you have to change the FM frequency being used to avoid competing with local transmitters
    1970 Lotus Elan +2S
  1. CD CHANGER Issue
    By andyam in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2012, 17:21
  2. multi disc changer for sale
    By madmark in forum In-Car Entertainment
    Last Post: 10th November 2011, 16:57
  3. Multi-tronic gearbox issue - possible fix
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2011, 13:09
  4. kufatec Multi CD changer
    By bdub in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th February 2011, 12:09
  5. Pioneer multi-changer
    By jediS3 in forum In-Car Entertainment
    Last Post: 3rd November 2004, 19:33
