JMB RetrofitsEM Tuning
    Jul 2011
    Le Mans 18" Tyre Options
    Hi all
    I know this topic has been done to death, however.......
    Roads here in Spain are worse than UK for pot holes and debris, so the boss has informed me the standard 19" wheels have to go (4 new tyres in 18 months, thanks to potholes).
    OEM tyre sizes are:
    255/35/19 = Dia. 661.1 mm
    245/40/18 = Dia. 653.2 mm
    However a closer match is
    255/40/18 = Dia. 661.2 mm.
    What am I missing if 255/40/18 is better match for speedo and keeping arch/wheel gap same as original. I will need to consider also the ET offset of new wheels also. But this tyre would give me more rubber/and volume over the rim.
    Any advice before I spen best part of 1K euros....much appreciated
    Apr 2012
    N. Wales, LL22
    1,224
    use the tyre sticker...
    Untitled by Ste_Nova, on Flickr
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Jul 2011
    Hi
    Thanks for your prompt reply
    I am fully aware of the sticker in the fuel cap....my question is questioning why Audi specify 245/40/18 when 255/40/18 is a closer match to the original 19" tyre size.
    Is it a ? of what they have in the factory
    Regards
    hazey7's Avatar
    Sep 2009
    170
    Thats a good question...
    One thing to consider is that a new tyre has 8mm tread depth and you can use them until 1 mm is left, that's an overall difference of 14mm in diameter from a new to worn tyre..... enough to cover your worries about an 8mm difference?
    Apr 2012
    N. Wales, LL22
    1,224
    maybe because the 255 wont fit on the skinny wheels
    VCDS in North Wales
  1. WHAT TYRE - BEING OFFERED 60+ OPTIONS!
    By WAFTER in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th November 2011, 20:31
  2. 18" RSTT Tyre size options? Whats best!
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2010, 13:28
  3. Wheel & tyre options: OEM or aftermarket copies?
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th July 2009, 00:01
  4. best tyre option opinions 225/40/18??
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2007, 21:55
  5. Options on a new A6 2.7TDi Avant Le Man?
    By MrBroon in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th April 2007, 23:53
