Results 1 to 11 of 11
    Oct 2012
    Yatton
    156
    Unhappy rear wash wipe problem
    Although I'm a newbie! to here would appreciate some help I've searched this problem but couldn't find anything. The rear wash wipe on my Avant has stopped working the motor works good and strong and the fronts work. The water from the rear just dribbles out I've blown the nozzles and stuck a pin in no change. I can't see any wet patches in the boot and checked the tailsgate, nice and dry so is the head lining. Where is the likely problem to be?
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    Hi bud.. Not sure if the same problem
    But my rear arm stopped working could hear the motor trying to go but no movement..
    I looked everywhere for problem turned out that the rear arm had just got abit stiff.
    Try put it on and then move the arm yourself ( gently )
    Hope this helps with that ... Fingers crossed .. Sorry if not mate
    Luke
    Oct 2012
    Yatton
    156
    Thanks Luke the rear arm works fine its just no water comes out.
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    Hmmm not sure if the rear jet is on te same pump as the front tbh ?? Would of thort soo :-/
    Sorry no help mate hope u get it sorted soon 👍
    Greeny233's Avatar
    Mar 2011
    Llangollen
    673
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    It does sound like the seals have gone inside the motor. You might not notice the water in the boot as it tends to leak down passed the boot catch.
    I'd take the boot rear panel off and get someone to operate the rear wash wipe and check to see if it is leaking.
    It is on the same pump as the front.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Hi guys
    I've done a refurb on my motor twice... so without repeating info here is link to my fixes...
    Link:- Audi A6 Avant ( 4F C6 ) Rear wiper motor removal / refurb / install
    I just hope you don't have leak on the pipework going to rear washer causing lack of pressure...
    I had nearly about three or so when I got my car last year and fixed the issue... a real PITA as it runs under carpet from washer fluid reservoir... took me two attempts to dry carpet...
    Oct 2012
    Yatton
    156
    Thanks for that i'll have a go at removing the trim to see if the piping has come off
    Mar 2007
    38
    I had much the same problem last year.
    Due to the cold weather the pipework to the rear froze and the joint in the pipe popped loose.
    It took a long time to locate where, and I was lucky (sort of) as it was the first joint off the pump (outside the badywork).
    The tank is inside the rear of the nearside (UK) wheel arch and to get at it you have to remove the wheel arch liner. I only realised where the leak was when I saw water dripping down behind the front wheel after yet another attempt to locate the leak by running the pump.
    Since then I have also had a problem with the rear nozzles furring up and ended up having to use a modelling drill to clear them out! (I do live in a very hard water area).
    Hope you get to the bottom of it soon.
    marsmail
    Oct 2012
    Yatton
    156
    Well interesting update seems the problem with my washer was the bottle top not fitting tightly with a little piece of self adhesive foam it seems to have cured it although the pressure isn't great, but it works
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    Happy days at least u have some joy
    Oct 2012
    Yatton
    156
    Yes hopfully someone will find this thread helpfull I never thought a poor seal on the washer fluid bottle cld cause such an issue
  1. Here's why some people's rear wash/wipe.....
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2014, 17:15
  2. rear wash wipe problem
    By WALTO TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2011, 12:54
  3. Rear wash wipe issues new problem.
    By Avant4me in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th February 2011, 16:03
  4. Rear Wash Wipe, Water leaking from wheel arch!
    By Gajjii in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2006, 01:13
  5. Rear wash wipe problem........
    By arS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st March 2006, 21:18
