Volks AutosEM Tuning
Results 1 to 8 of 8
    Mar 2011
    6
    Headlight range control unit ( 8P0 907 357) replacment procedureor even where it is?
    HI Guys
    I wonder if any of you know where this unit is and how to get to it ?
    if somebody has the procedure that would be great
    as I have an issue of the contol unit reports errors but the headlights still adjust which point to the control unit in vagcom and audi release notes .
    ( i have a early 4f2 2004 3.0tdi sline quattro )
    so i have a new unit thinking it was by the passenger fuse box , but it isn't there ...bugga
    anybody any ideas ?
    many thanKs
    Apr 2012
    N. Wales, LL22
    1,224
    its behind the glove box
    you can take the trim down to get to it, or just remove the whole glovebox (which i found easier)
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Mar 2011
    6
    Quote Originally Posted by Ste_Nova View Post
    HI there
    great thank for that
    if I want to drop the glovebox down is it just the screws under the glovebox and the ones in the inside roof of the glove box ??
    or ir there some art to it ?
    may thanks
    Martin
    Apr 2012
    N. Wales, LL22
    1,224
    it was easy from what i remmeber didn't need to look it up
    VCDS in North Wales
    Mar 2011
    6
    many thanks for that
    it was just that easy FFS
    5 screws 3 on the inside of the top edge of the glove box and 2 underneath on under the fuse box and the other directly opposite and the whole unit comes out .....I was done in under 30 mins with a new headlight range control and now no error ( touch wood & fingers crossed )
    I wish i had know that when i was scrabbling around contorted into UN-natural positions when I fitted my denson Ipod unit and also the cabin air filters .....
    wish i could say the same for changing the running headlight bulbs
    many thanks
    again
    M
    Mar 2011
    6
    ok an update to this
    I made the system re- learn the headlight levels using the VAGcom all is fine and it learned no problems , it runs trough the headlight dip / raise and set process in the vagcom no probs
    BUT
    when I turn the car on it used to run through a set up where the lights would dip raise and set , it does not do this anymore ????
    the unit I have is dated late 2008 . do more modern cars not bother with this start up any more ??
    or do i need to program it in vagcom if so anybody know how ?
    many thanks
    Apr 2012
    N. Wales, LL22
    1,224
    same part number on the before and after?
    VCDS in North Wales
    Mar 2011
    6
    mine was 8PO907357A and the new one was a 8P0907357J which should supersede the A,
    just been out and checked ant they do actually cycle , but it seems that they do it after the ignition is off after a certain amount of time . the old one did it ever time ..maybe that is what was wrong with it
  1. Replies: 1
    Last Post: 31st May 2010, 10:58
  2. "Dynamic Headlight Range Control Faulty" warning on DIS
    By gcs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2010, 15:48
  3. Headlight range control defective
    By Shabs in forum A8/S8 forum
    Last Post: 28th February 2009, 20:42
  4. headlight range control
    By kanievsky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2007, 15:57
  5. Dynamic headlight range control faulty
    By gav in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th August 2007, 07:53
