JMB RetrofitsChris Nott
    Jul 2012
    Exeter----Devon----UK
    6
    Key Ignition Fault
    Hi I have a strange one here, sometime I cant remove the key after switching off.
    I have to keep switching the engine on & off quite a few times to remove it?
    Have tried turning the wheel while trying with no joy. Also now & again the car wont lock
    by using key fob, just flickers red, end up having to lock it with key? Any clues out there please.
    2005 2.4 V6
    Mar 2007
    38
    The flickering red suggests that the key is "out of range" or more probably, the battery needs replacing (I don't know if you have done it before, but if not - that will be the most likely cause of that problem) without teaching to suck eggs - time is of the essence once the battery is out of the key to get the new on in (or risk the key being unrecognised by the car)
    As to being unable to remove the key - is yours an auto box? If so, you can only get the key out in park or neutral positions - I don't know about manual box versions.
    It could be that the selector is not "registering" where it is correctly, so the lock refuses to give up the key (I always assumed that this was a device to prevent the steering lock being activated if the car was in motion - I could be wrong!)
  1. Ignition On / Key Inserted Warning
    By Cruiser89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th November 2009, 18:12
  2. Key stuck in ignition barrel!
    By Mr K in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2009, 21:07
  3. 1998 Audi A3 Auto Automatic Keys Stuck in Ignition ... HELP!!!
    By alangordon in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2009, 14:53
  4. Ignition key switch sticky!!!!
    By Daz A3 TDI 130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 18:20
  5. ignition key problem
    By audi doodey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2007, 17:59
