Monster MotorsportEM Tuning
    Aug 2012
    Updating maps in A6 satnav 2007
    Hi,
    I have just bought my first Audi and I am really enjoying the experience so far. :-)
    My car is a 57 plate with 2006 maps on the disc in the dvd player. I thought that I would simply update the maps by buying a genuine 2012 Audi disk. However when I take the old disk out and put the 2012 version in, nothing happens and basically it tells me that there is no disk in the drive. I know it has to be me being silly but I have no idea what I'm doing wrong, can anybody help me please by guiding me in the right direction.
    Thank you in anticipation of your help.
    Thank you very much for taking the time to read my post.
    Regards.
    S
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,052
    Hi there, and welcome to ASN
    The first thing to check, I guess, is what type of 2012 disc you have...
    Audi 'factory' navigation comes in various flavours - there are a few variations of the RNS (Radio Navigation System), and a couple of MMI (Multi-Media Interface) - in simple terms, they all take different map discs.
    The C6 platform A6 (2004-2011) was fitted with MMI - '2G' (2nd Generation) and '3G' (you guessed it). On a 57 plate, it'll be (unless I'm missing something) 2G [the quickest way to verify on an EU market car is to look at the control wheel: if it's flat on top, you're 2G, if it's got a little joystick on top, you're 3G] - MMI 2G in turn, came in two [main] flavours - first MMI Basic - which has a monochrome screen and (IIRC) basic navigation (through the DIS display in the instrument cluster), and MMI High - which has a full colour screen.
    From what you've said, I expect that you've got MMI 2G High - so getting back to where I originally started, the first thing to check is that the disc you have is suitable for that system.
    If you post the part number of the map package you've got, I(/we) will quickly be able to check which system it's for.
    [Also, post moved to A6 secion ]
    All the best,
    Rob.
    Boot full of dog. Back seat full of lenses.
    Aug 2009
    182
    Quote Originally Posted by FactionOne View Post
    All the best,
    Rob.
    Sorry to labour the point but only 3G MMI High (hard disk based version) had the joy stick, the standard (DVD) version had no joy stick.
    I think the major means of identifying which version you have is that the for the 2G version the DVD (or in the case on MMI Low, the CD) drive for the navigation system is in behind the trim on the LH side of the boot, whilst in the 3G version it is in the glovebox. 3G was only available in the face-lift cars which are the 2009 model year so the OPs system is definitely 2G and because he has a DVD rather than CD (and thus presumably a colour display on the dash, as the MMI Low system had only a monochrome (red) MMKI display and single country navigation without maps) it is MMI High.
    If, as the OP claims, this is a genuine Audi DVD (ie got from an Audi dealer) then assuming it is the right version he should return it to the dealer and ask why it is not working - might be worth performing a factory reset on the MMI system first. If it has been bought elsewhere (as a genuine product) it is probably a copy and as such there may be all sorts of reasons why it is not working and he should take it up with the person he purchased it from
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I agree 2G MMI high system for sure, when a new disk is inserted into the DVD navigation in the boot the MMI system should prompt with the message. "New software available- would you like to update" or something similar.
    If you don't get that then it's either not the right disk or it's not been inserted into the boot Nav unit, some people do actually out it into the 6 CD drive.
  1. Updated maps
    By Adamantium in forum Satellite Navigation
    Last Post: 22nd September 2011, 21:55
  2. Updating the maps on my Tom Tom Satnav !
    By S3 Paul in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 27th January 2011, 15:06
  3. Newbie Q: A6 MMI satnav update?T
    By globesy in forum In-Car Entertainment
    Last Post: 12th March 2008, 17:48
  4. RNS-e whats 2007 Map DVD got over 2006 Map DVD
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd October 2007, 20:51
  5. Audi Concert 3 III & 2007 RNS-E DVD Maps
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2007, 09:43
